what a good shifting poin for a close to stock WRX? - Subaru WRX Forum
post #1 of 9 Old 03-08-2003, 10:20 AM Thread Starter
duba-u-R-x is an unknown
just wondering because after 5500 rpms it stops pulling so is 6k good or what?
duba-u-R-x is offline
post #2 of 9 Old 03-08-2003, 04:31 PM
koki is an unknown
6500
koki is offline
post #3 of 9 Old 03-10-2003, 08:52 PM
ljasonl is an unknown
Send a message via AIM to ljasonl
redline man, rpm is your friend. increasing RPM increases your HP.
also, every gear has a certain amount of torque multiplication. 220 ft/lbs of torque is not enough power to get a wrx moving from a standstill, at least not easily. therefore they put "lower" or "shorter" gears in the car which multiply the torque output a great deal. the drawback, you can only go so fast before you have to shift to a higher gear. so, 1st gear puts a ton more torque to the wheels than 2nd gear, and so on, so the longer you spend in the lower gears, the harder you accelerate.
there is a long, drawn out way to figure out the precise rpm you should shift at, but its a lot of work just to find out that 99% of cars should just run to redline
ljasonl is offline
post #4 of 9 Old 03-11-2003, 01:40 AM
BoostedBoxer's Avatar
BoostedBoxer is an unknown
Send a message via AIM to BoostedBoxer
i shift at 7000, it noticeably better than 6700 or 6800.....just wait til you're out on the road and race another stock wrx shifting before redline........
plus the revlimiter is at like 7400 or something....so stay off that and you'll be fine
"pure adrenaline attached to a license plate...isn't it time to experience one yourself?" - Dan Gurney
|-Boost Is Bliss-|
BoostedBoxer is offline
post #5 of 9 Old 03-11-2003, 10:15 AM
Gerlando is an unknown
But boost starts to drop of near redline, somewhere around 6500rpm.
-Gerlando.
<a href=
href=http://www.enjoychuck.com>EnjoyChuck</a>
Gerlando is offline
post #6 of 9 Old 03-11-2003, 10:40 AM
but you've still got that whole torque multiplication thing. i don't know if you realize it but you're actually putting like 500-1000 ft/lbs more torque to the wheels in 1st than 2nd, and it gets less with every higher gear.
man just go to the dragstrip and make some runs shifting at differnt points and see the for yourself instead of taking my word or anyone else's.
ljasonl is offline
post #7 of 9 Old 03-11-2003, 04:46 PM Thread Starter
thanks, that helps alot!
post #8 of 9 Old 03-11-2003, 10:15 PM
OZZYMY03 is an unknown
am i right in hearing that the STI has no rev limiter? i dont think that sounds right, but who knows...
OZZYMY03 is offline
post #9 of 9 Old 03-13-2003, 04:03 PM
IMPREZvWRX is an unknown
Send a message via AIM to IMPREZvWRX
It has a higher rev limit. Nobody in their right mind would run without overrev protection.
Chris
IMPREZvWRX is offline
