what to do with this stupid exhaust
anyways i scooped up a 03 this week and it has straight piping (catless) from the turbo all the back back to about the middle of the car (kind of like a super long DP) and then the stock exhaust system is hooked up..however... a butterfly valve is connected between the straight pipeing and the stock..and when you flick a switch it the valve blocks the stock part and sends all the air out of like a dump tube and makes the car run open down pipe i guess...anyways..the car needs work...oil change, brakes, wipers, tires and i dont have much change running around.. except for a new restrictor pill, a up pipe and a tune from my tuner...can i assume this to be a TBE and go ahead with my stage two tune or should i get rid of it and do it in complete straight piping?
