I will start by saying this was a trial and error kind of thing. My boost was not moving past .5 and i read all the threads about the pill etc.. But really thought something did not look right in the picture below. it looks like somebody tried to put everything back to stock with the parts they had. The vacuum lines were crazy thin as you can see and the T was just sticking in the air. I finally found a picture of a stock setup which was def. not what mine looked like. mine had a larger tube going from turbo to the T and then a thin vacuum hose from the wastegate to the T and the the last line running to the controller. the picture i saw was a larger looking tube from the turbo to the split of the tee with the other end connecting to the T straight to the waste gate. So really i have a direct line to the turbo and waste gate which i did not before. I test drove it after I made this change and my goodness i had no idea. For a week i have only had the car to .5 and on wot it sounded terrible and i thought the turbo was going to blow up...The car holds between .7-1 with me being very cautious of throttle. The turbo spools up much quicker and i can hear it spool much better. Have not ran it hard. There is no pill also. Any thoughts from some experienced owners or maybe a picture of what their stock setup looks like. The car runs fine without the pill so far. Should i head to subaru and get the stock lines and pill? Thanks ahead of time!
