I am upgrading my fuel pump w/ the malbro high output pump and I was looking over the install on the scooby forum and he tells you to use zipties to hold the pump in place but he does not tell what kind of tie to use. how long will a ziptie last in your gas tank? have any of you done this? I put a ziptie in a jar of gas today to see if it starts to brake down. it would suck if the zip just melted in the gas and my pump is just flopping around in there thanks
I have been reading some of the install guides on scoobymods and it doesn't say anything about ziptie's. I will be installing my walbro pump this weekend and I'll let you know how it goes.
this is were I saw the ziptie on scoobymods is there another post in this post the guy tells you to cut the pipe on the bracket use a hose and zipties to hold the new pump on the bracket (the zip I put in the gas has been in over night still there but getting hard)
nagyhead did you cut the pipe like the scoobymod guy did and use a 6" hose. the rubber mount is in the instal kit black pice rite thanks I still have about 3/4 of a tank of gas so about 2 days till I start
yeah Im not sure why he did that. I just did a walbro on my car and the fuel pumps were the same size. the only thing that is different was the rubber base, you have to use the one that comes with the walbro.
you can just put a walbro in there and go, you dont have to get a tune for a bigger pump, and if you cant use the factory mounting hardware for a walbro then use a metal hose clamp instead of a zip tie, when people start to stack up like two or even 3 walbro fuel pumps they just use hose clamps.
