Old 07-08-2005, 11:19 AM   #1 (permalink)
silver04's Avatar
Car: 04 WRX
Reputation: silver04 is an unknown
Send a message via AIM to silver04 Send a message via Yahoo to silver04
Walbro 255lph fuel pump install
Ok so I found a very well written and detailed DIY on scoobymods by "subedude" on this install. My question is, is it necessary to cut and modify the fuel supply tubing in order to fit the Walbro pump? The write up mentions how the Walbro pump mounts upside down compared to the stock one so the lines won't align and that's why you need to hack it up. Is this true?
The link is:
http://www.scoobymods.com/forums/showthread.php?t=4998
Thanks in advance!
Old 07-08-2005, 11:22 PM   #2 (permalink)
Car: 04 WRX
Reputation: hondaeater is more helpful than not
na, not true. THat mofo will fit in there, upright too. I"m not sure where the upside down thing came from! Fit's just right in my experience, without the bottom rubber gromet that it is If you want to keep the gromet, you'll need to trim the hoses. When you take out the assembly you'll see what i means.
Old 07-09-2005, 12:46 AM   #3 (permalink)
silver04's Avatar
Car: 04 WRX
Ah so it is a direct replacement or "plug and play" as long as you don't use that rubber bottom thingy? That's definitely good to hear. I wasn't really looking forward to hacking that stuff up.
Old 07-09-2005, 10:11 AM   #4 (permalink)
Car: 04 WRX
for me it was a direct drop in, i couldn't fit the rubber gromet on the buttom, but my FP was in there snug as a bug, and it taint going anywhere.
