-   -   vf48 vs big 16g (http://www.wrxtuners.com/forums/f52/vf48-vs-big-16g-25074/)
phatmike0704 01-07-2009 01:08 AM
vf48 vs big 16g
ok, so i ordered a b16g and my buddy gave me a vf48 for my birthday. which u think i should put in my car? i dont know much about the vf48 and its IHI, non-rebuildable. im trying to break 300whp
DreamEvil 01-07-2009 02:13 AM
hes a good buddy hah
dumdum 01-07-2009 08:06 AM
If the IHI is free use that and send back the 16G.They will be close in power.With that being said,once again,don't get wrapped up in dyno#'s.Your basing a # on a variable foundation.I can dyno my car on one dyno and get "a" then immediately get on another dyno and get "b".Even if they are two of the same type of dynos.Never mind the fact I'm sure you haven't even considered that altitude,barometric pressure,ambient temps,humidity,tune,supporting mods and the car itself all play apart in the final #'s.Some cars want to make power and some don't.
Chase 01-07-2009 10:37 AM
The clear choice is to use the VF turbo on your car, and give me the 16g since you won't be needing it. Glad I could help.
TurboRyan 01-07-2009 11:57 AM
I have a big 16g turbo, and i love it! it spools fast and seems to boost like a champ. Just my .02 cents.......
phatmike0704 01-07-2009 01:01 PM
hahahahahaa, that was actually pretty funny. a lot of people be tellin me that 16g would put out more. i got the 2.0. i cant find much on the vf48 so i resaearched more on the vf43, not many could reach 300whp
Boost Addict 01-07-2009 02:23 PM
[QUOTE=phatmike0704;212682]hahahahahaa, that was actually pretty funny. a lot of people be tellin me that 16g would put out more. i got the 2.0. i cant find much on the vf48 so i resaearched more on the vf43, not many could reach 300whp[/QUOTE]
vf48's are definitely capable of 300whp with supporting mods and a good tune! But as dumdum mentioned, there are too many variables to dyno figures. But for what it's worth, I've seen a stock 08 STI (vf48) put down 295 whp on a dynapack with only cat-back, intake and tune on 91 ACN fuel. It also put down about 340 ft lbs of torque to the wheels, but I'd expect lower torque figures on your motor due to smaller displacement.
dumdum 01-07-2009 03:22 PM
[QUOTE=phatmike0704;212682]hahahahahaa, that was actually pretty funny. a lot of people be tellin me that [B]16g[/B] would put out more. i got the 2.0. i cant find much on the vf48 so i resaearched more on the vf43, not many could reach 300whp[/QUOTE]Okay..there are 3 different types of 16g's,which on do you have?Small,Big or Evo III.And the VF39,VF43 and VF48 are basiclly all the same turbo regards to wastegate designs.All use the same compressor and turbine wheels.Also you don't yet grab the concept of comparing dyno #'s.Re-read my first post.........
phatmike0704 01-07-2009 05:19 PM
its a big 16g, i read ## last post, my current mods are tbe, cai,up pipe, type rs bov, and tuned. my headers and fuel just came in too. im just gonna mod my injectors since pinks are too much
baller_v24 01-07-2009 06:32 PM
i would keep the b16g and sell the vf48 and with the money you get from the vf48 use it to tune the car.
the b16g is slightly better so y not.
phatmike0704 01-07-2009 08:39 PM
16g it is
c2bcoolwrx 01-09-2009 08:17 PM
Doesn't the VF48 (from '08STi) use the LGT style flange?
So it won't work on the EJ205 w/o modification. So 16G then.
turmic 01-10-2009 08:33 PM
[QUOTE=c2bcoolwrx;212913]Doesn't the VF48 (from '08STi) use the LGT style flange?
So it won't work on the EJ205 w/o modification. So 16G then.[/QUOTE]
That's what I thought...but, from what dumdum has told me. The 08 STI uses the same TMIC layout as the older models. The 08-09 WRXs...definatly use LGT style turbos.
Boost Addict 01-10-2009 08:43 PM
[QUOTE=turmic;212976]That's what I thought...but, from what dumdum has told me. [B]The 08 STI uses the same TMIC layout as the older models[/B]. The 08-09 WRXs...definatly use LGT style turbos.[/QUOTE]
+1
08+ WRXs are using the LGT layout.
pb-king07 02-04-2009 11:54 PM
Is the EVO III the the biggest one of the 16gs????
