Thinking off getting a vf34 turbo pretty soon, just wanting to know how much of a difference i should expect from my stock turbo and current setup. btw, i will be getting an aps top mount intercooler (if i can find one) around the same time. How much of a hp difference should i notice w/ or w/out intercooler from my stock turbo?
My current setup (if there isn't already a link to it on here) is: slowboy 3" turboback exhaust complete with 4"-3" d/p and hi-flo cat, hks uppipe, greddy digital boost controller with boost set at 42%... about 16-17 psi, intake, forge blowoff valve, s-afc 2 air fuel controller, 660 injectors (major overkill), turbo timer, ported exhaust manifold and throttlebody, coolant bypass, and egt & boost gauges.
Will the difference in power be very noticeable? any idea how many crank/whp i'll be running? (there isn't a dyno within 6 hour of where i live) would i be way better off with a vf22. i like racing usually under 1/4 mile... what turbo is best for that? with vf 34 what shuld i run my boost at? sorry if too many questions, just answer what you can
thanks
