-   -   VF34 or Momentum EJ5-40T (http://www.wrxtuners.com/forums/f52/vf34-momentum-ej5-40t-9171/)
wrx904 10-01-2005 09:00 AM
I don't know which turbo to get. Here is a list of my mods. TBE, uppipe, SR intake, TMIC, and Cobb AP. I know the cobb ap has base maps for the vf34 but I plan on getting a protune a few weeks after I install the turbo. I would like to have 300whp and a reliable turbo.
knot04 10-01-2005 09:37 AM
VF34 if your gonna run the AP
wrx904 10-01-2005 10:54 AM
[QUOTE]VF34 if your gonna run the AP[/QUOTE]
I am going to get a protune a few weeks after I install the turbo. If I get the 40T I was just going to run the vf34 base map until I got the protune. I found a place that will do a protune for $150 1st hour and $80 per hour after.
nick4592 10-01-2005 02:43 PM
the EJ5-40T is a much better turbo all around...you need fuel upgrades to run it safely.
wrx904 10-01-2005 02:56 PM
[QUOTE]the EJ5-40T is a much better turbo all around...you need fuel upgrades to run it safely.[/QUOTE]
Do you have a EJ5-40T. Is there a big difference in power from the VF34.
Momemtum 10-01-2005 03:05 PM
Hello
TDC tuning can provide you with a accessport map for this turbo.
Brian
MT
nick4592 10-01-2005 03:08 PM
I switched from the VF 34 to the 40T (the 40T has been on my car for about 6 months now)and there is a HUGE difference between the two...I ran a 13.5 @101mph at 5400 Ft with the VF34 on race gas (105 Oct). I just ran a 13.4 @101mph at the same altitude on 91 Octane. Not only that the 40T provides power a lot faster and harder than the VF 34. Look around the web I have seen deals for the 40T and fuel system stuff.
wrx904 10-01-2005 04:34 PM
[QUOTE]TDC tuning can provide you with a accessport map for this turbo.[/QUOTE]
What would I need to do to get a map from them. I don't want to drive to far I live in Jacksonville, FL.
[QUOTE]Look around the web I have seen deals for the 40T and fuel system stuff.[/QUOTE]
I found a combo with the EJ5-40T, sti pinks, and a walbro fuel pump for $1299 free shipping.
How much psi could I get out of this turbo before it just blows hot air. Would it help if I had it port & polished.
nick4592 10-01-2005 05:07 PM
well...I have had it up to 24psi (DONT DO THAT- boost controler problem)....and it was still pulling; very scary....I use daily 18psi for 91 octane and 21 psi with 105 octane...
wrx904 10-01-2005 05:24 PM
Thats cool, so do you think I could get away with 20psi on 93 octane.
nick4592 10-01-2005 05:43 PM
oh yeah you should no issues with [U]proper tuning[/U] running 20psi on 93 octane.
wrx904 10-01-2005 06:36 PM
[QUOTE]oh yeah you should no issues with proper tuning running 20psi on 93 octane[/QUOTE]
I'll tell the shop that I am going to get the protuner that I what to get 20psi. Thats amazing, I am at 16.5psi now I can not wait.
What psi is the EJ5-40T efficient up to. I see on [url]www.momentumturbos.com[/url] that the flow rate is 580cfm. That is close to a deadbolt 18G, it has a 590cfm. :cool:
nick4592 10-01-2005 09:18 PM
Honestly I dont know the Max boost...I can find out though...
wrx904 10-02-2005 12:09 AM
Should I get a new clutch after I install the new turbo.
nick4592 10-02-2005 05:25 PM
[QUOTE=wrx904]Should I get a new clutch after I install the new turbo.[/QUOTE]
You should get a better/stronger than stock clutch with any power upgrade. you are looking at close to if not over 300whp with fuel mods and the EJ5-40T. A bigger intercooler wouldn't hurt but isn't needed right away.
