VF34: injector size - Subaru WRX Forum
post #1 of 10 Old 02-26-2008, 06:33 PM Thread Starter
KawBoyz11's Avatar
KawBoyz11 is an unknown
VF34: injector size
If im going 2 run a Cobb AP map for a VF34 on my 2004 WRX, will i have to use the Sti pink injectors(which are 565 cc) or can i use another brand/larger injectors. If so id like to run 680 cc injectors, just o be on the safe side for future mods. Also does anyone have an approximate 0-60 mph time and 1/4 mile time for the AP map VF34 setup? Id just like to get an idea of where id be at. Thanks for the help.
KawBoyz11 is offline
post #2 of 10 Old 02-26-2008, 06:46 PM
if you want to use anybody else's map (cobb's or whoever), you have to have the same exact fuel system. Yes, you should use pinks if the map is made for pinks. No other size will do. If you are going to get it tuned, you can put larger on there sure and then just get it tuned to handle them.
565ccs are enough for a VF34 though, it ain't that big.
post #3 of 10 Old 02-26-2008, 07:17 PM Thread Starter
KawBoyz11's Avatar
Thanks i appreciate the help. I figured id need to run exactly what the map said, but someone else on here told me to run 680 cc injectors. Also, will i be ok running an uppipe with this setup?
post #4 of 10 Old 02-26-2008, 09:35 PM
You will be fine running an up pipe.Its more for safety sake anyways. Removes the cat and the O2 sensor that are right before the turbo.
post #5 of 10 Old 02-27-2008, 11:40 AM
no, you want that cat gone if you're running an aftermarket Turbo. You need to switch that out. While you're swapping the turbo is the perfect time since it's much easier to take off if the turbo is out.
post #6 of 10 Old 02-27-2008, 08:38 PM Thread Starter
KawBoyz11's Avatar
Yea i planned on replacing the uppipe with a catless one. Mosc, do you know anywhere i can find directions on installing the VF34 turbo?
post #7 of 10 Old 02-28-2008, 11:27 AM
scoobymods or whatever has some walkthroughs maybe... any bolt-on turbo write up should work for you. No, I don't have anything offhand.
post #8 of 10 Old 02-28-2008, 11:35 AM
Longshot's Avatar
Turbo install / swap with pictures - ScoobyMods
This is a good one to follow with tons of pics.
DTRacing Tuned
Longshot is offline
post #9 of 10 Old 02-28-2008, 12:27 PM
thanks for linking
post #10 of 10 Old 02-28-2008, 12:48 PM
Longshot's Avatar
No problem at all.
DTRacing Tuned
Longshot is offline
