Subaru WRX Forum banner
Vf30/vf34/fp-16g
3K views 1 reply 2 participants last post by  Kjott21
#1 ·
Is there any cheaper turbo's that have the same spec's as the turbo's listed in the title? there's no tuning shops around tulsa, so i have to stick to the cobb base map, also on witch hunter they have some cheap injectors but their rated at 800+cc, would these work if the map calls for 565cc pinks? If not i hope they have some in 565cc, 150 bucks for a set of 4 injectors is a good deal including them paying a bill for ## stockers.
#2 ·
800cc injectors will not work with a map setup for 565cc injectors, but you can buy a basemap/etune off of a tuner for around $150 that will work just as good if not better than the OTS map that Cobb has.
Clark Turner Cobb Protune maps released. - NASIOC
Engines, Turbos and Tuning - NASIOC
That is assuming that you have an AP already. If not you could go with open source and there are a lot more people to choose from.
