vf22 turbo - Subaru WRX Forum
post #1 of 6 Old 09-14-2003, 10:05 AM Thread Starter
vf22 turbo
when do you get full boost and can you really push 25pounds of boost and is the vf30 when does that get full boost and how much boost can you push wiht that.
wrxnmh03 is offline
post #2 of 6 Old 09-14-2003, 10:45 AM
Cosmo's Avatar
Images: 15
You can run as much boost as you like. The question is will your engine hold up to it?
Cosmo is offline
post #3 of 6 Old 09-14-2003, 02:43 PM
fc735's Avatar
the VF22 REALLY falls on its face over 20psi..if you are wanting to pump massive cyl pressures....try the Garret 450, or the PE1850...or another hybrid version....TXS is working on a t3/t4..so i have heard. talk to nathan at TXS..he has a good knowledge of high power WRX's....but he is runnin a modded internal engine...stock REALLY doesnt like over 18psi..this i have found out.....
fc735 is offline
post #4 of 6 Old 09-15-2003, 02:10 PM
WRXblurr's Avatar
what would u have to do if you want it to hold up to more then 18psi.. better pistons, crankshaft, rods, or would u have to get valves and springs? thxs
WRXblurr is offline
post #5 of 6 Old 09-15-2003, 02:24 PM
fc735's Avatar
get a different turbo. the compressor wheel of the VF22 is not designed to hold high boost levels...nor are any of the VF series. for HIGH boost...a PE 1820, or 1850 are good, or the Garret 450.
as for the engine...DEF get the block changed over to a closed deck.and o-ring it, with head studs. the stock bottom holds up roughly to ~20psi...give or take. i am getting ready to do a 2.5 buildup for mine....
you are looking at a large investment to get the EJ20 to hold large boost levels....personally, i would run 18psi....ona stage 4 setup. vf34, tmic, sti inj. pump, etc......for good all around driveability.
fc735 is offline
post #6 of 6 Old 09-16-2003, 10:56 PM
what would someone hit with that setup? your estimate.
FaSTwRx2k3 is offline
