a-vcr isnt holding boost - Subaru WRX Forum
post #1 of 7 Old 02-02-2003, 03:27 PM Thread Starter
Angry a-vcr isnt holding boost
my a-vcr isnt holding my set boost i have it set @1.15 bar and it spikes to 1.40 - 1.50 and only hits fuel cut some of the time can anyone help???? !Cry!
imprezzor is offline
post #2 of 7 Old 02-02-2003, 08:56 PM
hey man i think ## gain or duty is set too high...
for 1.15 bar try setting it at arnd 33% to c if it helps....
also have u set the avcr to self learn yet??
Cant_C_Me is offline
post #3 of 7 Old 02-05-2003, 10:32 AM Thread Starter
thanks ill try setting it at 33% yes its been in self learn for awhile
post #4 of 7 Old 02-05-2003, 12:54 PM
That was the same problem that I had with my AVC-R before I took it out. It would either not reach my desired boost or sometime it would just way over shoot it. Thank you.
Ivan
www.HypnoticPerformance.com
hypnoticwrx is offline
post #5 of 7 Old 02-06-2003, 03:10 PM
AVC-R = Worthless POS.....
If ya want a good rock solid Boost-Controller , get a Profec-B. and a decent (psi not BAR) boost guage.....
BTW , 1 psi boost should = 11 Hp
WagonRex is offline
post #6 of 7 Old 02-17-2003, 07:34 AM
also try this, under settings (A) or (B) go to 6. Start duty....
there u can adjust ## duty for each gear....
as for me im using a 4.444 gearbox whereas in america u guys must be using the std 3.9 gearing so my settings may be abit off for ya...
but anyway try this....
1st gear +18-19%
2nd gear +6-7%
3rd gear +1%
4th gear -3%
5th gear -6%
hope this helps pal.....
try playing arnd wif the settings until ## satisfied.....
d:-)
post #7 of 7 Old 02-18-2003, 06:41 PM Thread Starter
1st gear +18-19%
2nd gear +6-7%
3rd gear +1%
4th gear -3%
5th gear -6%
d:-)
Thanx cant ill try it tonight
