Urgent Help Please! No Boost! - Subaru WRX Forum
post #1 of 16 Old 09-08-2009, 04:17 PM Thread Starter
clord05wrx's Avatar
clord05wrx is an unknown
Ok guys so I got the 06 STi intercooler and it was running fine. Im driving to the shore for the weekend and as Im driving I need to pass a car while in 5th gear so I hit the gas and I believe I boost spiked. The car shut down for a second the CEL came on and then the car started taking gas again. Made it to the shore fine the car got parked. When I left yesterday there was no boost I thought a line may have come loose. Today made sure all the lines were connected and everything is fine. Also my friend has an 06 WRX so we used his stock BPV to check to make sure my BOV wasnt leaking and Im still getting no boost. My boost gauge shows vacum and when I accelerate it goes up to 0 but then no boost. PLEASE HELP MEEEEEEEEE!!!!!!!!!!!!!!!!!!! !Cry!!Cry!!Cry!
Chucks stage 2 WRX tuned by Ray @ TurboTekTuning.com
16G it's so pretty
clord05wrx is offline
post #2 of 16 Old 09-08-2009, 04:38 PM Thread Starter
clord05wrx's Avatar
Also could this be the boost solenoid?????
16G it's so pretty
post #3 of 16 Old 09-09-2009, 09:50 AM
Possible that its the solenoid, but you should still be getting wastegate pressure. When I got my car tuned the BCS was stuck shut, but was still getting abuot 10PSI off the wastegate. Might have to pull the turbo and look at it to make sure it didnt lock up on you. Can you still hear it spooling up or not?
post #4 of 16 Old 09-09-2009, 10:55 AM Thread Starter
clord05wrx's Avatar
yea i can still hear it spooling.
16G it's so pretty
post #5 of 16 Old 09-09-2009, 11:02 AM
Is the CEL still on? Did you get it read? Is your car in limp mode?
You should downshift to 4th (or 3rd) if you want to accelerate quickly unless you're already going like 100 mph.
VisiX is offline
post #6 of 16 Old 09-09-2009, 12:09 PM
04wrxhart is an unknown
Your car is probably just in limp mode from the boost spike if that was the issue. Easiest fix is to disconnect your negative battery cable, step on the brake a couple times and wait a few minuets to reset the ecu. I have had this happen once to my car but i was still making 8psi on a stage two map when it happened. All I did was reset my ecu with my accessport and it was all better.
04wrxhart is offline
post #7 of 16 Old 09-09-2009, 01:45 PM
Or you have a boost leak.
dumdum is offline
post #8 of 16 Old 09-09-2009, 02:21 PM Thread Starter
clord05wrx's Avatar
the CEL went off by itself. Checked for all leakes put new clamps on everything. No leaks found and checked with a working stock BPV. Going to try and reset the ecu. Thanks for the input guys.
16G it's so pretty
post #9 of 16 Old 09-09-2009, 04:06 PM Thread Starter
clord05wrx's Avatar
Tried the ECU reset to no avail. Next option guys????
16G it's so pretty
post #10 of 16 Old 09-09-2009, 05:18 PM
check the inlet of your turbo. Pull the turbo inlet hose and check inside the turbo inlet to see if the compressor wheel is rubbing. You might have a bad turbo.
Did you ever replace your uppipe? Could be a chance that a piece of the cat broke off and messed up your turbo.
post #11 of 16 Old 09-02-2010, 11:56 PM
bob450 is an unknown
I had the same problem.. couldnt find what was wrong, finally discovered that the ceramic/metal core in the uppipe came loose and lodged itself up right under the turbo, put an aftermarket catless uppipe on and solved
bob450 is offline
post #12 of 16 Old 09-03-2010, 02:08 AM
some times I really wonder why Subaru put a cat in the early up-pipes...
post #13 of 16 Old 09-03-2010, 09:34 AM
...taken from wrxinfo.com:
"The main purpose of the up pipe cat is to keep cold start emissions low until the main catalytic converters warm up. Using a catless uppipe is a violatation of section 203 of the Clean Air Act. Each state has statutes that cover this subject as well. There have been no known reported cases of catless uppipes causing state emissions test failures."
...so everybody who's running a catless up pipe is breaking the law!!! See you all in jail. Oh NoeZ!!! :eek: Hahahah
I'd be willing to bet that Subaru started using catless up pipes because they do still have two after-turbo cats, so that's probably sufficient to comply with U.S. emissions standards. They probably also realized that the up pipe cat material can break apart over time and cause turbo failure and other major damage, which could cost them lots of money in the long run if they had to keep making such repairs under warranty. That also reinforces the idea that it's good to wait a few years after new car models come out to buy them - wait for the companies to iron out the kinks in the design and whatnot. Read: nobody buy the 2011/12 STi. Wait until 2013/14 at least.
Here's evidence: look at the changes that were made to the 2008 WRX and the 2004 STi. Are they bad cars? No. Are the models that followed "better?" Arguably, yes.
Now that I've gotten extremely off topic, I'll stop.
post #14 of 16 Old 09-22-2010, 03:33 PM
Puma03's Avatar
Puma03 is an unknown
Hey the same thing is happening in my 03 right now. I recently put in a new engine due to engine damage from the previous owner. It wasnt pulling full boost and found that my cat was flying into my turbo (16g). I put in an Invidia up-pipe and downpipe this past weekend. The cat had frozen up my turbo but we were able to release it by blowing some compressed air through it and it sounded fine. Put it all together and found the turbo inlet boot was shot to hell. After driving it I am still having the same problems as you were. It stays at 0 psi and wont go any higher. I am planning on replacing the inlet boot. But I am wondering how much damage the cat might have done to the turbo even though it seemed alright after we did some work on it? Any insight?
Puma03 is offline
post #15 of 16 Old 09-23-2010, 07:41 AM
Did you take the turbo out and check the shaft on it ? More can happen to a turbo than just the wheel.
I said shaft... ha
