Uppipe replacement (no cats) on WRX - Page 2 - Subaru WRX Forum
post #16 of 35 Old 02-19-2008, 03:35 PM
burkej62 is an unknown
I just put on a Perrin catless up pipe and I unplugged my sensor and did not install it and have no CEL's yet and I put about 500 miles on it all ready . Maybe i'm special?
burkej62 is offline
post #17 of 35 Old 02-19-2008, 03:40 PM
twentyclowns's Avatar
twentyclowns is an unknown
simple. buy an uppipe that has the egt bung still
and further more, buy a downpipe first
and further more still.....get engine management before u buy ANYTHING!
case closed
twentyclowns is offline
post #18 of 35 Old 02-19-2008, 04:43 PM
Originally Posted by White GDA View Post
Taken from the Perrin online instructions for their Uppipe install.....
You're taking a 2.2 kohm resistor (1 watt?) to solve the CEL.
It basically invovles unplugging the O2 sensor plug (last one underneath near where all the plugs are on the pssger side sturt tower) and sticking the resistor into the female ends of the plug.
The resistor in the picture is 2.2kohm but it's not really possible to judge the wattage rating. The markings are "2" (first red band), "2" (second red band), "x1000" (third orange band), "gold tolerance" (fourth gold band).
in other words, it's says it's a decent quality 2.2kohm resistor.
Any power rating should work. 12v over 2.2kohm is V^2/R watts which is 12^2/2200 which is 65 milliwatts so even a quarter watt resistor is more than enough.
post #19 of 35 Old 02-19-2008, 05:21 PM
mikeydotkom6's Avatar
mikeydotkom6 is an unknown
im getting my up pipe tomarrow so if you have a bung for the egt you dont have to put the resinator in?
mikeydotkom6 is offline
post #20 of 35 Old 02-19-2008, 05:24 PM
never mind the resistor
post #21 of 35 Old 02-19-2008, 05:27 PM
If you have a Cobb AP or similar EM, you don't need either because you can simply disable the code from triggering a CEL.
If you don't, you either need to put the resistor in or yes, you can re-use the sensor in an aftermarket up pipe but that's really not recommended. It can break off and destroy your turbo just like the cat you're replacing (which is the whole point of the mod).
Get em to disable it or use a damn resistor. It's not hard.
post #22 of 35 Old 02-19-2008, 05:36 PM
thats true
thanks
post #23 of 35 Old 02-19-2008, 05:57 PM
will a up pipe make my cars exhaust any louder?
post #24 of 35 Old 02-19-2008, 06:42 PM
Longshot's Avatar
Not really, FYI the CELs you guys may get for the EGT could be P1312, P0546, and P0545..just so you know what to disable ahead of time. I got rid of those 3 one by one until I had no more CEL.
DTRacing Tuned
Longshot is offline
post #25 of 35 Old 02-20-2008, 12:33 PM
White GDA's Avatar
White GDA is an unknown
Doesn't the EGT CEL trigger only if temps get too high? So in theory you won't trigger a cel if you decat?
I did the resistor mod as a precaution, but re used my EGT probe in the bung on my new BPM uppipe.....I didn't have a bolt short enough to seal properly....didn't reconnect the sensor though.
^^Well here's my take on it. I've found that in lower rpm/beginning of turo spool the car sounds a bit heavier...exhaust is a little more pulsing (on a stock DP) than it was before.
It isn't amazingly louder...but for my setup....it is noticeable.
White GDA is offline
post #26 of 35 Old 02-20-2008, 01:43 PM
yes, you can do that White GDA, you also now have an EGT sensor dangerously exposed in a way it was not designed to be and in many cases, they break off and blow your turbo. Much like the cat you just replaced...
In other words, the entire purpose of the mod is for turbo safety and putting the damn sensor back in there makes the whole thing kind of moot.
Also, it will trigger a CEL when it gets hot.
post #27 of 35 Old 02-20-2008, 04:08 PM
SUBY777 is on thin ice
Question Plugs
Where Can I Get The Plugs To Place In The 02 Sensor Spot.
SUBY777 is offline
post #28 of 35 Old 02-20-2008, 08:00 PM
i have a magnaflow catback it is a littile to quiet for me and i dont have the money to buy a downpipe so i was hoping that the up pipe might help a little. ups is having trouble finding my house i have been waiting sience the 12th for my uppipe i see them drive by my house every day how hard is it fedex found it yesterday for my boost controller it ended up being broke so i had to send it back
post #29 of 35 Old 02-20-2008, 08:33 PM
Longshot's Avatar
m12 - 1.25 size bolt, gotta be pretty short too
DTRacing Tuned
Longshot is offline
post #30 of 35 Old 02-21-2008, 08:00 AM
White GDA's Avatar
Well I disconnected the EGT sensor and did a resistor mod. I only used the prope to plug the bung in the uppipe. Yep I should have gotten a bolt I guess...but it was too dran hard to find.
I think my EGT sensor was grenaded anyways....as it looked like tiny stubby piece of metal. LOL. Could it really cause all that harm? Out of curiosity....this ever happened to anyone before?
IF it does cause damage then...well...I got an excuse to get a bigger turbo.
