Uppipe Question!? - Page 2 - Subaru WRX Forum
post #16 of 22 Old 11-22-2005, 12:13 AM
DUBXTCY's Avatar
Images: 18
DUBXTCY is an unknown
Send a message via AIM to DUBXTCY
nope, no cat on the uppipe of 06s... If you did add an aftermarket uppipe, maybe <1 whp on the dyno in my opinion.
-KJ
Cobb Stage II 2006 WRX
DUBXTCY is offline
post #17 of 22 Old 11-22-2005, 01:07 PM
dannyv is an unknown
You might want to compare inside diameters of the different pipes. If you're worried about installation you can get one with a flex.
dannyv is offline
post #18 of 22 Old 11-22-2005, 10:34 PM
stileguy's Avatar
stileguy is an unknown
here in australia i simply remove the rattley heat shields, cut the cat out of the up pipe and replace it with a straight piece of stainless and heat wrap the whole thing. cost bout 10-15 au$ when you remove your stock ones you might notice the pipe diameter is the same the whole length of the up-pipe until 1 inch from the top flange where it has a taper. this accelerates the exhaust gasses just before they hit the turbine. subaru do this to help the turbo spool quicker.
stileguy is offline
post #19 of 22 Old 11-22-2005, 10:41 PM
Abismo is an unknown
yea i couldnt believe it either, was crusing nasioc and low and behold learned that the 06 doesnt have a cat on the UP.
Abismo is offline
post #20 of 22 Old 11-23-2005, 12:28 PM
IBAUCLAPlaya's Avatar
I like the Turbo XS one. Has a flex joint, and retains the stock inside diameter.
IBAUCLAPlaya is offline
post #21 of 22 Old 11-23-2005, 02:01 PM
ManicsWrX's Avatar
ManicsWrX is more helpful than not
Invidia TBE No cats on my 06
Invidia seems to be good quality
Chris- ▼SbiΣ Mi▼
242 AWHP / 318 TQ
ManicsWrX is offline
post #22 of 22 Old 11-23-2005, 10:17 PM
wingless's Avatar
wingless is an unknown
I have the Helix with the flex joint, got as package deal with headers from gruppe-s. No complaints, great sound, awesome power as part of total mods.
wingless is offline
