uppipe downpipe help - Subaru WRX Forum
post #1 of 9 Old 12-31-2005, 01:22 AM Thread Starter
04rex's Avatar
hey guys, I'm stuck between 2 sets of up-pipes and downpipes. I'm looking at getting the Cobb stage 2 accessport setup. anyways, i was stuck between getting the Cobb up-pipe and down-pipe to make it a complete Cobb system, or if i should stick to my original plan of getting the Helix Up-pipe/Down-pipe combo. in either setup, i will get it with the catalytic converter. your help is much appreciated. thanks.
04rex is offline
post #2 of 9 Old 12-31-2005, 10:04 AM
hey 04rex...
actually, you will get the same performance with either brands...
it all boils down to whether you want in all cobb or if you want to use the helix...
But I think you get better value with the helix...
It's cheaper in price but not in quality... and most importantly it performs just the same..
wrx555 is offline
post #3 of 9 Old 12-31-2005, 03:54 PM
Ian
Ian's Avatar
Send a message via AIM to Ian
Originally Posted by wrx555
hey 04rex...
I couldn't of said it better myself
Ian is offline
post #4 of 9 Old 12-31-2005, 06:01 PM
nick4592's Avatar
TurboXS up-pipe is the s###....that is all
nick4592 is offline
post #5 of 9 Old 01-09-2006, 02:46 AM
Fodera04's Avatar
do you guys know of of any downpipes that have the has the spot for the co2 sensor
Fodera04 is offline
post #6 of 9 Old 01-09-2006, 10:37 AM
nick4592's Avatar
Most aftermarket DP's do....I know for sure APS does
nick4592 is offline
post #7 of 9 Old 01-09-2006, 02:11 PM
WRXtreme's Avatar
My Helix has a bung at the end of the downpipe for the rear o2 sensor, it also has a bung near the turbo that is for a wideband o2 sensor, but I have a plug in it.
WRXtreme is offline
post #8 of 9 Old 01-22-2006, 04:42 PM
IBALONGWRX's Avatar
Send a message via AIM to IBALONGWRX
i just ordered the perrin up-pipe. i was going with helix but the diameter is larger (on helix) and the perrin is the same size as stock header. i just read that it is better to keep the same diameter up-pipe for the stock turbo
IBALONGWRX is offline
post #9 of 9 Old 01-23-2006, 06:52 PM
04WRXn00b's Avatar
Go with invidia, you wont' be disappointed. You can get a used upipe for around $100 and they now started making catted DP's. Invidia is by far the best build quality, but if its price your after the helix will do the same job for less.
04WRXn00b is offline
