Upipe egt hole What size bolt? - Subaru WRX Forum
post #1 of 9 Old 11-14-2011, 05:19 PM Thread Starter
ejs0806 is more helpful than not
Hey guys just got my invidia uppipe, i dont think i have factory egt becuase i dont have any gauges. What can i use to plug up the hole on the ividia?? sadley it didnt come with anything so im kinda lost can i just go to home depot and find a bolt that threads in and just loctite the hell outta it? Whats everyone else doing with em?
ejs0806 is offline
post #2 of 9 Old 11-14-2011, 06:15 PM
Not sure, but you should still have that egt probe on even a bone stock car. Look toward the windshield of the passenger side engine bay mounted high there should be a few electrical connectors. egt is Gray and has a cord that goes down to plug in to that thread.
post #3 of 9 Old 11-14-2011, 06:19 PM
wagonracer's Avatar
The stock UP has an EGT sensor in it, so what you do is put that in the new UP and research what value resistor you need to get from radio shack to prevent the inevitable EGT code. Look for EGT resistor fix. It's a $.29 part
That being said you can, always take the UP to a hardware store and find a bolt that fits the bung, but you'll still need the resistor fix.
BTW, I don't recommend installing that in an '02 without EM, as it can cause "bad things" to happen to piston #3
Research, then mod....
Cullen
wagonracer is offline
post #4 of 9 Old 11-14-2011, 07:06 PM Thread Starter
thanks guys i just didnt think i did becuase i have no gauges. and i already read up on the resistor needed could i also do that for the 02 sensor?? (I already have a CEL from no cat in the down pipe lol) if not no biggy EM will clear that up anyway im getting a cobb this weekend aswell if this one works. found another great deal on a local one. I thought the bad thing happened with #3 with an intake?? Damn this sh*ts getting hard to keep up with lol
ejs0806 is offline
post #5 of 9 Old 11-14-2011, 07:20 PM Thread Starter
Also my cars an 03 i dont think that makes a diff but i first made the account before going to pick up an 02 i was gunna buy to find out more before going to cali to buy it bottom line is i wasted a weekend of time and $$ driving out there for it to be a piece.. It looked good but you could clearly see the car wasnt cared for etc... so i bought a stock 03 instead
ejs0806 is offline
post #6 of 9 Old 11-14-2011, 07:22 PM
wagonracer's Avatar
Flash it to stage 2 with the AP and it will be "all good". The performance gains are noticeable, and it will fix your o2 sensor code (assuming it's the downstream one) It will also prevent damage from running too lean with the catless UP. Have fun
Cullen
post #7 of 9 Old 11-14-2011, 07:28 PM Thread Starter
Yeah thats the plan.. im hoping it will be a stupid noticable powergain where its night and day difference
ejs0806 is offline
post #8 of 9 Old 02-07-2012, 02:07 PM
ride5000 is an unknown
fwiw, catless up pipes don't make cars run lean.
ride5000 is offline
post #9 of 9 Old 03-23-2012, 12:58 AM
Klone's Avatar
Klone is an unknown
^^ i second that haha
Klone is offline
