upipe is in! - Subaru WRX Forum
post #1 of 9 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
I just installed my wrxpower uppipe. Did it from below (without removing the Turbo) Took me 11 hours by myself (including setup, cleanup, and 2 trips to hardware store for 14mm wrench and sockets). If I had jacked up the engine a bit, I would have saved 2 hours fiddling with trying to remove the old uppipe. On the positive side, I didn't lose any oil or anti-freeze from removing the Turbo. I also had 0 stripped or siezed nuts, bolts, or studs.
mikeWRX is offline
post #2 of 9 Old 12-31-1969, 07:00 PM
HRTATAK's Avatar
Cool Mike. I hope to purchase and install mine soon.
HRTATAK is offline
post #3 of 9 Old 12-31-1969, 07:00 PM
Guest
Guest
Posts: n/a
Can you post the website where you ordered that up-pipe?
post #4 of 9 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
Got it from Troy at:
Aftermarket Powersports Group Inc.
DBA: WRX Power Parts
email: wrxpower@hotmail.com
web: www.wrxpower.com
fax: 225-252-0552
AIM: kartmart
MSN: 2k2wrx
ICQ: 137924100
call and tell him your a clubSti member and you can get it for $249. This is the same pipe Gerlando has in the uppipe install mod section.
mikeWRX is offline
post #5 of 9 Old 12-31-1969, 07:00 PM
This is definately a great mod and Troy is a very nice person to deal with.
Congrats on the install Mike! I swear, after doing mine, I feel like I can pretty much install anything on my car (as long as I don't have to open up the engine block or tranny)
Gerlando is offline
post #6 of 9 Old 12-31-1969, 07:00 PM
Send a message via AIM to Getta1
any majorHP increase ??
Getta1 is offline
post #7 of 9 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
It does feel like it's making a little more power, so I would guess about a 10HP increase. There have been dyno plots that confirm this, but I haven't dyno'd my car yet. However the noticeable differences are better throttle response and faster turbo spool up with less lag.
mikeWRX is offline
post #8 of 9 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
Smokin! Tightened up the bolts on the downpipe thinking there might be a leak and took it out for a spin. The car started smokin real bad. Pulled over to check it out, and noticed it was power steering fluid that was smoking. Turns out, the compression fitting on the power steering line was way loose and after jacking up the engine, it started leaking PS fluid onto the downpipe. Had to tighten up the compression fitting and put in more PS fluid. It seems all good now, but It still makes a whistling sound at high RPM's and full throttle. Thinking it may just sound that way now because I cant find any leaks when doing a check around the fittings with my hand while the car is running. Maybe I need to check while under full boost at 6-7K as this is the only time it makes that noise.
mikeWRX is offline
post #9 of 9 Old 12-31-1969, 07:00 PM
Wow, well I'm glad it wasn't anything major! I've noticed a new exhaust sound at idle and low rpms and I'm afraid it might be an exhaust leak Guess I'm going to have to check mine this weekend too.
Hopefully I'm just being paranoid after hearing your story.
Gerlando is offline
