up pipe question - Subaru WRX Forum
post #1 of 15 Old 02-07-2011, 04:51 PM Thread Starter
2004 WRX is an unknown
up pipe question
I just ordered an accesport from nasioc. i just have a 3 inch catback right now. i am wondering if i put on a new catless up pipe if i would need to run a map different from the stage 1 map on the AP?
2004 WRX is offline
post #2 of 15 Old 02-07-2011, 09:55 PM
Yes, a catless up pipe on a map made for a catted up pipe will change the spool of the turbo enough to throw the map off.
post #3 of 15 Old 02-07-2011, 10:09 PM
fuapiti's Avatar
Get the DP also and go Stage 2... I did it a few years ago and still feels great!
fuapiti is offline
post #4 of 15 Old 02-08-2011, 05:45 AM
A catless up pipe will be fine to run on the "stg1" map... Just watch your psi.
Aftermarket or stocker from a newer WRX/STi ?
post #5 of 15 Old 02-23-2011, 10:16 PM Thread Starter
i would get an aftermarket upipe most likely. would one from an STI make a difference or do they work about the same?
2004 WRX is offline
post #6 of 15 Old 02-24-2011, 02:42 AM
KCsubikid is an unknown
You can run a catless UP stage 2 though right?
-Jason-
Protuned 4EAT- Helix DP, Grimmspeed CC UP, Grimmspeed EBCS, SPT CBE
KCsubikid is offline
post #7 of 15 Old 02-24-2011, 06:02 AM
^^Not too sure, but I remember ppl in the past doing it and being fine till they got a tune
You shouldn't stray from the map notes on the OTS COBB maps. You can run whatever you want on the car.... but be wary and get a tune shortly thereafter. Use the OTS maps as a "limp mode" to get to a tuner. As Chris said above my previous post.... You NEED mapping done, but be careful.
post #8 of 15 Old 02-24-2011, 06:49 AM
Yes you can run an STI or 06/07 WRX up pipe as they are both catless and somewhat easy to find and cheaper than most aftermarket ones. And yes you can run a catless up on a stg2 setup. Most up pipes are generally the same diameter as stock, just with no cat in it.
post #9 of 15 Old 03-30-2011, 08:17 PM
BBT0903 is an unknown
catless up pipe
I just installed a catless UP in my 2002 WRX. Vehicle has no other modification. Should I get it tuned? I drove it after install and seems to run fine. I wasn't looking for any more power, just didn't like the possibility of cat failure and ruining my turbo. I just bought the WRX a couple weeks ago and if it needs a tune I would probably do more mods. A tune around here cost $500.00. Thanks
BBT0903 is offline
post #10 of 15 Old 03-30-2011, 09:05 PM
yes you need a tune asap, the cattless up changes the spool characteristics!
post #11 of 15 Old 03-30-2011, 10:20 PM
sicc_soul's Avatar
sicc_soul is an unknown
Isnt it pretty much safe to say anything besides a cat-back will need a tune?
Have to be young and stupid to be old and wise
sicc_soul is offline
post #12 of 15 Old 03-30-2011, 10:37 PM
not always, the bugeyes tend to be able to do intake and DP's without tunes but an UP will just throw the ECU into a fit eventually
post #13 of 15 Old 03-31-2011, 07:17 AM
VD5505's Avatar
I got rid of the Pyro on mine when i did the up pipe and block the hole off. Just make sure to get the OEM gaskets for your UP and DO NOT use those cheap gaskets that look like Alum. Foil haha.
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #14 of 15 Old 03-31-2011, 08:54 AM
Buddy of mine on his 05 Baja blew out the Grimmspeed gaskets as well.... So OEM is prob the correct route. Good point.
post #15 of 15 Old 03-31-2011, 07:09 PM
thanks
Thanks for all the info! I guess I will be doing some more mods before getting it tuned though. I'll probably do STI TMI, catted down pipe and 3" cat back.
Any suggestions on a catted down pipe?
Thanks again
BBT0903 is offline
