im going to be installing a turboxs uppipe this weekend and i have a question. the one i got doesnt have a place for the egt sensor. what am i supposed to do about it? the instructins on theyre website didnt mention it. thanks
your uppipe doesnt need an egt sensor unless you want to run one. If thats the case you need to get the pipe "tapped" or drilled/threaded at a machinist shop
If you dont have an accessport, go to radio shack, buy a 1/2 watt 2.2ohm resistor. they come like 5 to a pack or something, its only like 50 cents. cut the tips down a little and stick it in the click where the EGT sensor plugs into. that will make your ecu think your egt is still plugged in and it will not throw a cel. Dont forget to put some electrical tape on the end of the electrical connector that you put yours resistor in.
