im thinking about getting an up pipe but i have some general questions first. i am goign to get a catless thats a no brainer, but are you able to hear the turbo spool signifigantly more? and is there any performance/sound diifference between a solid piece or a flex joint? and one last question, im having trouble locatign where its at, so any help would be awesome. thanks in advance
there is no real sound/ proformance differences between the two.
the uppipe is located under the turbo, you probally have the heatshields all in place, and cant see it. In all honesty if you cant find the uppipe you probally shouldn't try to replace it. to get the stock uppipe you either have to loosen the motor mounts and jack the motor up, or remove the turbo.
You will hear the turbo a lot more if you remove the air baffle from the wheel well...and it would help with performance a little bit more too
