up-pipe options for '02 WRX - Subaru WRX Forum
post #1 of 8 Old 09-19-2006, 04:03 PM Thread Starter
npage08 is an unknown
I have an '02 Rex with an exhaust leak in the stock up-pipe. I am using this as an excuse to upgrade to a non-catted up-pipe and just have a few questions. First off, the setup on the car is a Vishnu stage 0 reflashed ECU, cat-back exhaust, Perrin short ram air intake... as far as I know (I bought it already modified). I don't care too much about extra power, I just want an up-pipe that will last (high quality).
Q's:
Is it better to go with a flexible up-pipe or to go with no flex?
therefore, Is the Perrin up-pipe or the Helix up-pipe a better bet?
Are there any others I should consider?
One other mod I guess I should mention is that my car has STi engine and tranny mounts... Don't know if that would effect the need for flex or not in the up-pipe.
Thanks.
npage08 is offline
post #2 of 8 Old 09-19-2006, 05:05 PM
Chris Rx's Avatar
Chris Rx is an unknown
go with a helix flex uppipe.
Chris Rx is offline
post #3 of 8 Old 09-19-2006, 05:48 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
The Perrin and Helix are bot hvery good UP's. I have the Perrin UP and everything has been fine with my setup.
Ian is offline
post #4 of 8 Old 09-19-2006, 05:51 PM
Strider327's Avatar
Strider327 is an unknown
You might be in luck since there is someone selling a Brand new Helix up-pipe for about $130 shipped.
http://www.clubwrx.net/forums/showthread.php?t=150350
Check it out and good luck.
Strider327 is offline
post #5 of 8 Old 09-19-2006, 06:34 PM
9d2TSi's Avatar
Optimally, get new gaskets and find a used STi pipe. The flex section in the Helix pipe will wear out eventually. Then it too will leak.
9d2TSi is offline
post #6 of 8 Old 09-20-2006, 10:20 AM Thread Starter
Thanks guys.
Does anyone know anything about the Bosal uppipe? http://www.daddysscp.com/dcart4/cata...pipe-p-49.html I was looking into getting the STi pipe as Stacy said and I came across this. The stealth factor seems nice, plus it comes with gaskets. If I understand correctly Bosal has a pretty good rep. I'd just be interested to know if it holds up well.
Thanks again.
npage08 is offline
post #7 of 8 Old 09-20-2006, 04:54 PM
9d2TSi's Avatar
Bosal makes nice parts. I got my Helix pipe for about $40 less though. If you look around you can usually find STi pipes for around $60-$80 on ebay.
9d2TSi is offline
post #8 of 8 Old 09-20-2006, 06:16 PM
oldfartracer's Avatar
oldfartracer is more helpful than not
The HKS is cheap and good. Got mine for $75.
oldfartracer is offline
