up-pipe leak? - Subaru WRX Forum
post #1 of 10 Old 09-19-2003, 11:23 AM Thread Starter
intec is an unknown
up-pipe leak?
hey i am still having the same problem that i was having before being that when i am in 2nd or higher gear at a low rpm and i go wot the boost shoots up to about 17 psi before it settles to 15 where i have my mbc set at. the rpms also briefly rise and then fall accordingly. when the turbo spools i also hear a loud whine it sounds almost like a supercharger, i read a post on nasioc and someone suggested it could be an up-pipe leak. i just took the car to the dealer and they took off the whole exaust including the up-pipe. before i take the up-pipe off again i wanted to know if anyone has had a sililar experience. thanks for the help
intec is offline
post #2 of 10 Old 09-19-2003, 02:25 PM
WRXblurr's Avatar
WRXblurr is an unknown
if its an aftermarket up pipe you have.. you should put on new gaskets.. thats what i was told..
WRXblurr is offline
post #3 of 10 Old 09-19-2003, 04:36 PM Thread Starter
intec is an unknown
i have a stock up-pipe that i gutted the cat out of
intec is offline
post #4 of 10 Old 09-24-2003, 11:59 AM
Ohio_WRX's Avatar
Ohio_WRX is an unknown
Send a message via Yahoo to Ohio_WRX
gaskets
Did you use new gaskets? If you didn't you probably have a leak. I know it is a pain, but get new gaskets installed and torque them down good
It is only called speeding if you get caught!!
Visit: http://www.silverwrx.com
Ohio_WRX is offline
post #5 of 10 Old 09-24-2003, 05:45 PM
Cosmo's Avatar
Images: 15
Welcome to my world!
Uppipe leaks are a common thing. Well, most of the time. I'm getting ready to weld my headers and uppipe together (actually, I think Joey is going to do it, once I buy the headers from him) to completely eliminate that problem.
Cosmo is offline
post #6 of 10 Old 09-24-2003, 09:17 PM
fc735's Avatar
Mig welders are my friend. i had to change upipe gaskets twice a week, for a month, before i finally welded my header to gether. i tend to find ways to fix repetitive issues...such as valvetrain problems...shim under conversion..here i come!
fc735 is offline
post #7 of 10 Old 09-25-2003, 02:08 PM
WRXblurr's Avatar
soo getting an up pipe and putting new gaskets on it.. it will still leak about once a month?
WRXblurr is offline
post #8 of 10 Old 09-25-2003, 05:18 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
Depends on how much power you are pushing. Normally it shouldnt. We dont all have a WAGON POWAAA like fc735
Che
Tut4u2 is offline
post #9 of 10 Old 09-26-2003, 08:25 AM
Cosmo's Avatar
Images: 15
It doesn't have anything to do with the power. It has to do with how they are made. The faces on the flanges aren't always completely parallel. That's where the leak comes from.
Cosmo is offline
post #10 of 10 Old 09-26-2003, 09:45 AM
TheRex's Avatar
TheRex is an unknown
Send a message via AIM to TheRex
i had a nasty leak with my TXS until i put the gaskets from SubyDude.com on there, havent had a leak yet *knocks on wood*
TheRex is offline
