Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-On Tech (EJ205 2.0L '02-05 WRX)
Old 10-12-2009, 03:39 PM   #1 (permalink)
Reputation: blueman is an unknown
Up pipe and headers.
What is a good up pipe that wont throw CEL and what is a good set of headers??
Old 10-12-2009, 04:05 PM   #2 (permalink)
Just get an STI up pipe or 06/07 WRX one as they are both catless. And why do you want/need headers? There are a coupe different types.
Old 10-12-2009, 05:11 PM   #3 (permalink)
midniteblack's Avatar
Club Region: Southwest
Reputation: midniteblack is more helpful than not
Send a message via AIM to midniteblack
Any up-pipe is going to cause a CEL from eliminating the cat.
Old 10-12-2009, 09:19 PM   #4 (permalink)
Originally Posted by C89ZX7R View Post
Not Really. It actually comes from eliminating the egr probe that the catless up-pipes don't have a provision for. A cel fix can be used on the egr probe.
I didn't say the cel can't be eliminated. I think you mean EGT probe. Yes, not having it in use will throw a cel. Also, some cat-less up-pipes DO come with the egt bung and if one decides to use their egt sensor without the cat, it will throw an exhaust gas temperature circuit malfunction code.
Old 10-13-2009, 05:06 PM   #5 (permalink)
Would my stock up pipe be a bad choice to keep on my car if i Stage 3 it. and if i change headers will it throw emission codes or would i need to?
Old 10-13-2009, 07:19 PM   #6 (permalink)
Because your stock up pipe has a catalytic converter in it... read this: Uppipe FAQ: Read if you are thinking of buying one! - NASIOC
and this: Header FAQ: Read if you are thinking of buying one! - NASIOC
2007 WRX Limited Sedan
Cobb AP Stage 2
Old 10-14-2009, 01:58 AM   #7 (permalink)
Well regardless, even a stock 02-05 wrx can benefit from running a cat-less up-pipe due to safety issues regarding the catalytic converter, like Man Show said. Btw, what is your idea of going stage 3?
