Up pipe gaskets - Subaru WRX Forum
post #1 of 8 Old 11-15-2011, 08:54 PM Thread Starter
ejs0806 is more helpful than not
Up pipe gaskets
What gaskets do i actually need when replacing an up pipe? my invidia finally came after a month! I have no idea what gaskets are needed and couldnt find a simple answer. Could i us the right stuff gasket maker or is that a no go because of it being on the block? I had heard it was good stuff and used it for the down pipe to mid pipe gasket and the mid pipe to rear and it worked great i have 0 leaks but could i do this on the up pipe or no?? Also if not could someone list me off the gaskets im actually going to use? Also does the up-pipe actually change sound at all??
ejs0806 is offline
post #2 of 8 Old 11-15-2011, 09:08 PM
wagonracer's Avatar
Here's what you need in this link:
GrimmSpeed Either these, or get them from the dealer. Do it right, or pay somebody else to do it right. Gasket maker is not an option
Cullen
wagonracer is offline
post #3 of 8 Old 11-15-2011, 09:15 PM Thread Starter
Thanks what ones do i specifically need?? Engine to exhaust manifold, exhaust manifold to cross pipe, and exhaust manifold to upipe, then uppipe turbo?? im gunna grab em from the dealer this week. I liked the idea for gasket maker for the rear part of my exhaust cus its on and off a lot. I put it on last weekend and its already coming off again because its to quite and im gunna get rid of the resonator i think depending on how it sounds with uppipe. I bought legit gaskets for down pipe etc...
ejs0806 is offline
post #4 of 8 Old 11-15-2011, 10:52 PM
Head to exhaust manifold, exhaust manifold to up pipe, up pipe to turbo, downpipe to turbo. All in you'll be getting six gaskets. You need the downpipe-turbo gasket because you need to pull the dp to remove the up pipe bolts.
post #5 of 8 Old 11-16-2011, 07:12 AM Thread Starter
Damn never thought of that alright thanks I guess ill just order it from grim speed it will probably be cheaper then the dealer for better stuff anyway
ejs0806 is offline
post #6 of 8 Old 12-26-2011, 10:24 PM
Ridge10's Avatar
Ridge10 is an unknown
Why would I need 6 gaskets? Would'nt I just need 3?
-Derek
Ridge10 is offline
post #7 of 8 Old 12-27-2011, 05:53 AM
If you are just replacing the UP, yes.
post #8 of 8 Old 01-03-2012, 09:48 PM
Ridge10's Avatar
Sorry to jack this thread, but if I were to use these instructions, http://www.scoobymods.com/showthread...49.html?t=6649 would I just need the Uppipe to Turbo, Uppipe to Manifold, and Turbo to Downpipe like it says? Or do I need the Exhaust manifold to Head also? 2 of them? And what about the crosspipe?
-Derek
Ridge10 is offline
