UP/DP Combo: Perrin or Helix? - Page 2 - Subaru WRX Forum
post #16 of 33 Old 08-30-2004, 05:20 PM
IBAUCLAPlaya's Avatar
Originally Posted by Quack
IF you need to fix the CEL for the DP, you can do the mechanical fix (which is a pair of foulers stacked) for the UP fix you can either put the EGT probe back in or use the resistor. if you have a Cobb AP, Stg2, both are fixed for you.
Well the light won't go on, but an OBDII will still pick up those codes.
IBAUCLAPlaya is offline
post #17 of 33 Old 08-30-2004, 06:03 PM
Quack's Avatar
which one (Fix) are you referring to?
Quack is offline
post #18 of 33 Old 08-30-2004, 06:51 PM
The AccessPORT one.
post #19 of 33 Old 08-30-2004, 07:15 PM
Quack's Avatar
nope. reads OK. i have checked it with a seperate OBDII scanner that i have.
Quack is offline
post #20 of 33 Old 08-30-2004, 07:25 PM
Really? I remember hearing that it will just turn the light off for those two codes not clear them. I thought I even called Cobb to ask them that question. But I guess I was wrong. Props to the AccessPORT if it does that. Also Quack I see you are from my area, maybe I can get a ride in the 12 second wagon once it is completed
post #21 of 33 Old 08-30-2004, 08:19 PM
Quack's Avatar
the CEL is illuminted when the sensors are outside the programmed range. the Cobb Stg2 (and above) rids the CELs by widening the parameters. SO, the OBDII systems will read "Ready" eventhough the cat's have been removed.
hoping to get into the 12's, but regardless it'll be the most modded wagon up here
maybe i should charge people for rides to make the $$$ back from the upgrade.
Quack is offline
post #22 of 33 Old 08-31-2004, 12:01 AM
hipo_wrx's Avatar
Send a message via AIM to hipo_wrx Send a message via Yahoo to hipo_wrx
lol, unless you offer , 10 bux!
does the perrin similator work on the rear o2? i havent tried mine yet but ill probably get it put in weds. with the plugs. well, theres alot of fixes out there now. ones bound to work!
hipo_wrx is offline
post #23 of 33 Old 09-01-2004, 09:03 AM Thread Starter
latinWRX's Avatar
Correct me if im wrong, but im getting this vibe that none of you that have a complete aftermarket exhaust system have any cats.
latinWRX is offline
post #24 of 33 Old 09-01-2004, 10:59 AM
Quack's Avatar
i still have 1 cat (until saturday) it's in the UP.
i did have a Bosal DP, stock 3rd cat and bosal cat-back, so i had 2 cats for a while.
Quack is offline
post #25 of 33 Old 09-01-2004, 02:05 PM Thread Starter
latinWRX's Avatar
So....what do you guys think about the Stromung Turboback exhaust?? I dunno, but I think im gonna have to go with them cause they are the only ones that offer a catted DP that i've heard good things about. Ok the thing is this.....I dont want problems with cops. So when they check for a cat under the car they can find one and I get let off easily. Now, I could go straight through with no cats and tell them that the resonator that the Borla has on the midpipe is a cat but that could be risky no? C'mon....I need people to convince me on this one.
latinWRX is offline
post #26 of 33 Old 09-01-2004, 02:08 PM
Quack's Avatar
or you can get a short DP, the Mad-dad 3CE ( http://www.daddysscp.com/cgi-bin/plu...ategory_Code=E ) and your cat back.
Quack is offline
post #27 of 33 Old 09-01-2004, 10:39 PM Thread Starter
latinWRX's Avatar
Or I could go with the primary section and catted secondary section of the stromung and then match it to the Borla exhaust....yea...that sounds plausible.
latinWRX is offline
post #28 of 33 Old 09-02-2004, 01:37 AM
hipo_wrx's Avatar
i have no cats and probably will only use the stock dp for show at testing. i dont like cats. especially with them all gone i seen a 3+ mpg increase on the same type of driving as before exhaust mods. i also have a 69 pontiac, of course it didnt come w/ them but my 78 plymouth did and its a wonder i havent gotten rid of it's.
hipo_wrx is offline
post #29 of 33 Old 09-02-2004, 03:06 PM Thread Starter
latinWRX's Avatar
the thing is that if the cops catch me without any cats its a $500 dollar ticket.
latinWRX is offline
post #30 of 33 Old 09-03-2004, 01:49 AM
hipo_wrx's Avatar
sounds reasonable enough
hipo_wrx is offline
