Unusual exhaust setup? - Subaru WRX Forum
post #1 of 9 Old 11-18-2007, 07:35 PM Thread Starter
Impulse is an unknown
Hey all.
I got an Apexi N1 catback in my WRX. For those who don't know, it carries a 2.5" mid section, with a 3" axleback.
I'm in the market for a DP, but I'm aware that most DP's are full three inch. Would this create a problem on my current setup?
Also, will a 3" DP bolt up to my current 2.5" mid section piping (in terms of flanging etc)? I'm not sure about the other brands, but I've confirmed that the JDM 3" Cusco Div WG DP will work on my car fine because it has a 2.5" reduction right at the end of the DP, where it would normally bolt on to a catback.
However, availability and pricing have been obvious setbacks. Would the other brands (say HELIX etc) that offer full 3", bolt up on my setup? If not...which other brands have this 2.5" reduction near the end of the DP?
Any help would be great!
Impulse is offline
post #2 of 9 Old 11-19-2007, 08:13 AM
Boostbuddy's Avatar
Boostbuddy is an unknown
Most Downpipes will work with that set-up...I suggest researching what you would like to use and work from there..
What is your budget on this project?
Why don't you want to go with a full 3" exhaust system?
Boostbuddy is offline
post #3 of 9 Old 12-02-2007, 09:21 PM
scoobydo0204 is an unknown
i got a 3" downpipe off of ebay for a think 130 shipped to my house and that bolted up to the rest of the cat back
scoobydo0204 is offline
post #4 of 9 Old 12-03-2007, 07:37 AM Thread Starter
^^But what dia. was your catback that it bolted to? 2.5"?
Impulse is offline
post #5 of 9 Old 12-03-2007, 07:47 AM Thread Starter
Thanks for the reply Boostbuddy!
Well, I'm working with a limited budget, so I figure I'll just be able to afford a DP fornow. I'll be checking your site to see what's available
Any you recommend?
Impulse is offline
post #6 of 9 Old 12-03-2007, 08:41 AM
Boostbuddy's Avatar
Any you recommend?
If you are just going with a 'stock' rear section I recommend the Megan...it is cheap and easy
post #7 of 9 Old 12-03-2007, 10:50 PM
yes it was a 2.5"....3" and 4" down pipes bolt up to the stock exhaust to
post #8 of 9 Old 12-11-2007, 06:35 AM
BsTdWgN is an unknown
my cobb DP has a 4 inch mouth and it tapers down to 2.5 where it bolts up to the catback it sounds nasty i deffinately reccomend it
BsTdWgN is offline
post #9 of 9 Old 02-07-2008, 12:03 AM
xKurtisx's Avatar
xKurtisx is an unknown
i also have the apexi n1 catback exhaust for my 06 wrx and i was wondering if the cobb dp will bolt on up with the n1?
xKurtisx is offline
