TurboXS or Perrin Up-pipe - Subaru WRX Forum
post #1 of 16 Old 10-16-2008, 10:38 AM Thread Starter
Jcarv20 is an unknown
I've cut my options down to these final two up-pipes, now i just wanted to gather your guys opinions to help with my final decision. Looking for positive or negative feedback, also which is easier to install, quality (i'm guessing is good for both), also the TurboXS has a flex section so i'd like input on that if there's any, thanks a bunch!
Jcarv20 is offline
post #2 of 16 Old 10-16-2008, 12:00 PM
I would buy whichever is cheaper. Also there are a few other brands I'd go with if they were cheaper. There are dozens of good uppipes on the market. It's not a complicated part, it's just a few inches of steel.
post #3 of 16 Old 10-16-2008, 12:25 PM Thread Starter
ya so far i was thinking of the TurboXS it's cheaper by like 50 bucks, i just didn't want to buy something from a brand i know nothing about and have it crack or what not, i also research and saw the Perrin Up-pipe doesn't have a bung for the EGT or whatever it is sensor and you need to do the resister mod. So wouldn't one with a bung like the XS or another brand be easier to install.
Jcarv20 is offline
post #4 of 16 Old 10-16-2008, 12:46 PM
I bought one from DC for my old WRX... it had a flex section and worked perfectly. No complaints. Probably cheaper than TXS as well...
post #5 of 16 Old 10-16-2008, 02:08 PM
blk02wrx is an unknown
Send a message via AIM to blk02wrx
you might also want to look at the invidia uppipe. i have one and it's great. and the egt sensor might not come out of the old uppipe. mine didn't and just snaped when i tryed so i got a new one from subaru for $50.
O2 PEARL BLACK WAGON with some modds
blk02wrx is offline
post #6 of 16 Old 10-16-2008, 02:10 PM
Don't put an egt sensor in the up pipe. You're just asking for problems. Seriously.
post #7 of 16 Old 10-16-2008, 02:26 PM Thread Starter
so just plug it and leave it hanging there (figurtively speaking)? Cause my understanding (probably wrong) is that i don't need to do the resistor thing because my Cobb AP will take care of that issue.
Jcarv20 is offline
post #8 of 16 Old 10-16-2008, 04:45 PM
seanwrxwagon is more helpful than not
Yes and Yes. Leave it hanging and don't do the resistor mod. The factory EGT keeps you from frying the up pipe cat. Get rid of the cat and you don't need the EGT.
seanwrxwagon is offline
post #9 of 16 Old 10-17-2008, 04:58 AM
I've had ~5 uppipes or so including the old and new turboxs uppipes, and perrin. Let me tell you... both of the txs uppipes fit PERFECTLY. As good, if not better than stock. They also appeared to be the best quality (imo)... MUCH better than perrin, and yes, even better than grimmspeed (by a little).
Btw, don't leave the egt sensor hanging. Take it off... out of your car... completely. You don't need it anymore.
WReXd is offline
post #10 of 16 Old 10-17-2008, 09:06 AM Thread Starter
Thanks guys, all good advice, clears up a lot of my questions.
Jcarv20 is offline
post #11 of 16 Old 10-17-2008, 10:05 AM
Yeah I didn't mean to actually leave it hanging. I think there is a connector somewhere. Just follow the wire.
post #12 of 16 Old 10-17-2008, 01:51 PM
awdturb is an unknown
i have a HKS, i dont trust the flex pipes and the hks was cheep and easy to install....
awdturb is offline
post #13 of 16 Old 10-17-2008, 02:28 PM
I debated with myself about the flex section as well. I decided that I would get a flex so engine movement doesn't get transmitted to the turbo/DP. I had heard about flex sections failing but it seems to be rare. I got a Hop Up Racing up pipe for cheap (less than $100) but this is one of the simpliest parts you can put on a car. It's hard to mess up but I still would not recommend a $10 ebay one.
post #14 of 16 Old 11-11-2008, 12:35 PM
wrxracer03 is an unknown
The "flex" sections on the up pipe are not really a big advantage or disadvantage to installation or use once installed. Both are the exact same in quality I would recomment the Perrin that is what my buddy got without the "flex" pipe and he is very satisfied. I will be making the same upgrade soon.
wrxracer03 is offline
post #15 of 16 Old 11-11-2008, 02:13 PM
The problem with the flex pieces is some companies put them at the ends of the pipe to save money while helping fittment. Flex sections should not be used near bends. The Grimmspeed uppipe for example places the flex in the flat section in the middle of the up pipe which puts it far enough from the bend to avoid problems.
Flex sections are great, they're just more likely to fail. You minimize this by minimizing the stress they'll see. Whenever you have a bend in the pipe, the air will push against the side at higher pressure. It will also get more particulate friction. In other words, the bendy part is where pipes wear out first. Flex sections in these areas are the real problem. A flex section in a straight section should work fine.
