just replaced my tmic to the sti tmic, when doing so i lost my aftermarket turbo cooler. heard something about blanketing your turbo, what should i do? any advice will help or a direction to a site to buy what i'll need. appreciate all input.
wait, so you lost your heat shield or it won't fit anymore with the sti topmount? your options would be to buy a stock heatshield (cut to fit if you have an aftermarket d/p), an aftermarket heatshield (cobb, spt, etc) or a turbo blanket. i used a cut to fit turbo heat shield on mine since a stock heatshield won't fit over my turbo. the $37 kit Thermo-Tec Turbo Wrap Kit - JEGS
Find a used one if possible and cut it. My stock unit fits over my 20G, and works with my TurboXS TMIC with no issue and is hard to tell its not stock.
um i work 9 hours a day i don't spend 13 online so when i get the time i respond. to everyone else thanks for the input i tried to fit the heat shield i currently have, the sti top mount is to bulky for it...thanks for the direction midnite just ordered it.
