turbo upgrade - Subaru WRX Forum
post #1 of 18 Old 12-11-2011, 04:46 PM Thread Starter
wrxwagon05 is an unknown
turbo upgrade
hi everyone i just switched to this form. i used nasioc before and i couldnt get a straight answer.i have a 05 wrx wagon with few mods
They include:
invidia n1 race
invidia catless downpipe
cobb ap stage 2
cobb sf intake
my question is where do i go from there. i heard i should switch to a catless uppipe.I want to do a bigger turbo was thing about the vf 39 or 18g?I know i have to do a bigger intercooler tmic or fmic which one? and what else do i need to do? can anyboby help me?
wrxwagon05 is offline
post #2 of 18 Old 12-11-2011, 04:54 PM
Most guys go the vf39 route next. You'll need Sti or equivalent injectors, better fuel pump, Sti top mount to boot. and you definitely want to change the up pipe.
post #3 of 18 Old 12-11-2011, 04:58 PM Thread Starter
that should put around 300 whp? thats my goal
post #4 of 18 Old 12-11-2011, 05:12 PM
If you can afford it, get a 16G turbo instead. Im still not a strong believer or advocate of the STI turbo swap. But either way, get you a nice TMIC, bigger injectors (around the 650cc range), a fuel pump, a catless up pipe (either off an sti or 06-0 wrx will work just fine) and if you can also get it, a good 3 port EBCS (like the grimmspeed unit) and then get yourself a protune.
post #5 of 18 Old 12-11-2011, 05:34 PM Thread Starter
with 300 whp would i need to upgrade anything on my suspension?
post #6 of 18 Old 12-11-2011, 05:38 PM
Never hurts to have better handling. There is plenty of improvement to be had over stock with just a good set of sway bars and endlinks, upgraded brake pads, stainless steel lines, and better fluid.
post #7 of 18 Old 12-11-2011, 05:47 PM Thread Starter
also would TurboXS tmic be a good choose?
post #8 of 18 Old 12-11-2011, 05:57 PM
Thats what I run on my 07 WRX with a 20G, works great, looks nice also. Its just a bit of a PITA to install. Its MUCH larger than stock, so paying attention and having patience with installation pays off with it.
post #9 of 18 Old 12-11-2011, 06:01 PM Thread Starter
as for the turbo goodspeed 16g and the Blouch 16g which one would be a good choose?
post #10 of 18 Old 12-11-2011, 06:03 PM
I personally dont know anyone running a goodspeed unit. My 20G is a Blouch product, and I love it. I know many subie guys running all kinds of different Blouch turbos and they love them. Blouch is a great company with great support.
post #11 of 18 Old 12-11-2011, 06:06 PM Thread Starter
ill go with the Blouch then. thank you for all your help
post #12 of 18 Old 12-11-2011, 06:07 PM
Good luck with everything. Let us know how it all turns out.
post #13 of 18 Old 12-11-2011, 07:18 PM
If your gunning for 300whp might I add that I would also start saving some money for a new gear set in your future.
Turbowise your gonna need at least an 18g to hit 300whp. 20g would be best bet and a bit safer. Intercooler I'd go with either a Turbo Xs, I run the Hyperflow, or if you can swing the cash outlay a Process West is very nice, but VERY pricey.
Injectors I'd say 750's, but 850's would be better and they would give you a bit of head room come tuning time...
post #14 of 18 Old 12-11-2011, 07:38 PM Thread Starter
i also read up on that. the tranny should hold if you dont drive recklessly and dont launch. so should i go with the 16 or 20g??
post #15 of 18 Old 12-11-2011, 09:22 PM
20g, it's what I am currently running. You sacrifice a bit of low end power for awesome top end. Also go with a TD05 turbine housing and not the TD06. If you go with a Blouch call and talk to Mike he will steer you in the right direction. The reason I said what I did about the transmission is from years of watching people destroy them even on stock power levels. Mine lasted a good while and to be honest I think it only has a bent shift fork and I am making well over 300whp. It really does come down to the driver, but a few of us on here honestly believe mine was just a factory freak transmission...
