Old 07-08-2008, 01:30 AM   #1 (permalink)
04paulieWRX's Avatar
Car: 04 WRX
Reputation: 04paulieWRX is an unknown
turbo install questions
i have a couple of questions regarding my desired setup. right now i am stage 2 with a 3inch divorced wastegate dp via cobb ap. i want 300 torque. i think the best way to get this is with a big 16g evo iii and the supporting mods (injectors, fuel pump). I also want to run an external wastegate.
now for the questions
if i used a fmic, are there big gains over a big tmic? what else do i need for a 16g, i know i need a new up-pipe. if my dp is 3 inch divor wastegate, do i need to swicth to a 4 inch bellmouth?
lastly, is this all work i can do myself, and then bring to a tuner to get tuned. how hard is the install. if i wont be able to, does anyone know how much a shop would charge to do this kind of job?
thanks
Old 07-17-2008, 11:48 PM   #2 (permalink)
Speedogomer's Avatar
Car: 05 WRX
Reputation: Speedogomer is an unknown
Send a message via AIM to Speedogomer
A shop will charge you a significant amount, but it's cheaper and more satisfying to do it yourself. Weather or not you can do it depends on how good of a mechanic you are.
A 3" should be fine.
A FMIC won't make huge gains over a big TMIC, and a FMIC is generally more laggy than a TMIC setup. It generally will run cooler though, and some extra power could be had by it, although it is more pricey.
-Justin, aka Gomer
(sold)-05 WRX
(new)-04 Cadillac CTS-V
Old 07-17-2008, 11:48 PM   #3 (permalink)
Car: 05 WRX
Also, at that power level, watch that tranny, new gears will be on your shopping list soon.
-Justin, aka Gomer
(sold)-05 WRX
Old 07-21-2008, 11:31 AM   #4 (permalink)
Trinity54's Avatar
Car: 05 WRX
Reputation: Trinity54 is an unknown
thanks
in my personal humble opinion , running a external wastegate wont be overkill for a big 16G.but if you really intend to , get something around 38mm.
if you want torque and responsiveness, i would suggest sticking to 3" bellmouth , upgrade your injectors to something like the sti 550cc ,walboro 255 fuel pump,stick to a top mount but something reasonably larger than the STI( aps would be a good choice ) and get your car tuned/tuned again.
at the same time you might wish to look at transmission parts like a stronger clutch with lighten flywheel as well as small improvements like stiffer gearbox and engine mounts.
am sure you will have a very fun car by then taking out those big a@@ turbo rides on short sprints.
Old 07-21-2008, 12:45 PM   #5 (permalink)
Longshot's Avatar
Car: 05 WRX
I agree with the EWG, would not be overkill for a big 16G. My only input will be to get 650cc injectors instead of the STi pinks. It gives the tuner more room to play and this way your injector duty cycles aren't 95+%. The fmic will work ok with a big 16G, but will be a bit more laggy than a bigger tmic.
DTRacing Tuned
Online
