Turbo Help? - Subaru WRX Forum
post #1 of 8 Old 06-05-2006, 11:26 AM Thread Starter
BoostedFury is an unknown
Turbo Help?
Well I'm about to upgrade my turbo really soon...my question was whether or not the 16G turbo bolts on directly to all factory lines or will i be required to buy separate water lines for the installation, I've been getting mix opinions on this? Like if I buy the 16G fr turbochargers.com will that turbo bolt on directly w/out problems? And will I need to upgrade my intercooler?
BoostedFury is offline
post #2 of 8 Old 06-05-2006, 12:17 PM
you will need injectors, a bigger fuel pump, a bigger intercooler, some form of engine management. You will also probably want exhaust work namely a catless uppipe and aftermarket downpike and likely a cat-back exhaust.
so no, requires more than just an intercooler but yes, it does use the stock lines.
post #3 of 8 Old 06-05-2006, 12:38 PM Thread Starter
Yeah sorry, I forgot to mention that I already have TBE w/up-pipe installed and I have on hand sti pinks, fuel pump, and the money for a re-flash. I'm just trying to decide if I should get the 16G or not. I dont really have money to upgrade my intercooler just yet. Will it be really damaging to run my stock intercooler for a few months w/the 16G?
post #4 of 8 Old 06-05-2006, 12:49 PM
9d2TSi's Avatar
If you have a protune done, the tuner is going to set your car up aith a safe tune. Keep in mind that you won't be getting the most from your turbo, but once you upgrade your IC, you can re-tune and get better gains.
9d2TSi is offline
post #5 of 8 Old 06-05-2006, 03:04 PM
the stock WRX intercooler is really tiney man, you're best off sticking with the stock turbo until you can upgrade it. Even the stock turbo is somewhat limited by the stock intercooler
post #6 of 8 Old 07-13-2006, 04:49 PM
LilSix's Avatar
LilSix is an unknown
Pinks are not recommended with a 16g. The only thing you need is larger banjo bolts. FP should be able to point you in the right direction.
LilSix is offline
post #7 of 8 Old 07-14-2006, 06:10 AM
Depends on what 16G your talking about.
small:510cfm
big: 550cfm
evo/super:575cfm
Pinks will be fine with the small and big 16G but some people like to have some headroom.It really comes down to your tuner and how much max boost you will run.
note: Subaru used pinks to fuel the earlier STi's with 16g's.
dumdum is offline
post #8 of 8 Old 07-14-2006, 11:27 AM
stileguy's Avatar
stileguy is an unknown
actually the wrx and sti with 16g turbos used grey side feeds on the wrx and yellow side feeds on the STI the greys were 380cc and the yellows were 440cc wrx didnt get end feeds till 2001 and the STI with pinks had vf34 or 35s depending on age.
Nothing makes Torque like 1.7Bar of Boost
stileguy is offline
