tumblers - Subaru WRX Forum
post #1 of 3 Old 09-21-2004, 06:22 PM Thread Starter
hipo_wrx's Avatar
Send a message via AIM to hipo_wrx Send a message via Yahoo to hipo_wrx
tumblers
i seen a replacment performance tumbler housing to delete them and was wondering where in power levels should this be done? and whats it worth then?
hipo_wrx is offline
post #2 of 3 Old 10-01-2004, 09:59 AM
Send a message via AIM to Theformula
Tumblers restrict air flow, these can really be upgraded at any point. Im planning on lifting the restriction on the intake track all at once. That is, extrude hone intake, tumbler deletes, and gasket match all the intake, tb, and tumbler orfices. I already have a FMIC, CAI, and ported Throttle body. All those things would get you about the most free flowing intake system possible. My tuner has preached to me alot on the amount of gains he sees from the gasket matching, tumbler deletes, and extrude honed intake. No matter what the rest of your parts are this will give you gains. Make sure you have the injectors to support it though.
Also, you dont need to buy the $500 APS tumblker deletes. You can find many shops around that can machine your tumblers for you for $ saving and you get the same thing. Id try Axis in st. Loius. sure they do it.
Theformula is offline
post #3 of 3 Old 10-04-2004, 05:43 PM Thread Starter
hipo_wrx's Avatar
thanks! i was wondering about that for a while now. saw that someone else did on here or somewhere. good info!
hipo_wrx is offline
