I have a permanent tumble generator code on my ECU... I have the 1088 and one other one...
'right tumble generator valve stuck open'
'right tumble generator valve low output'
My right TGV is obviously stuck, and I have not touched it since the code was found many many miles prior... The valves do nothing more than recirculate Exhaust gas through to more completely combust it and lower emissions... they lower emissions, that's it... I don't know what effect the sensor would have if removed, but i know when the valve stuck open, there is no real affect (on my car at least) ### its been like this since just after install TXS turboback and not bothered the function of the car at all. I considered letting subaru fix this, until i talked to the subaru mechanic about it and he said to me "a tumble generator what"... that made me a bit too nervous... so i just left well enough alone... the utec stops the CEL light from coming on... and despite scanning the OBD II many times at my dad's place, the 1088 cannot be removed from the ECU... It simply cannot be deleted like other codes can... i don't know why???
Worth noting... Phil (formerly of TXS) and knowledable about WRX's and UTEC said that they removed the TGV's from his car altogether... and that the car ran a little funny sometimes between shifts at 3500 rpm... but that it did not bother the car enough to worry him...
Subaru has never used TGV's before the 02 WRX, does not put them on any other of its models, and are not used on the STi, not sure about the 03/04 WRX's... but all it was used for was to pass low emissions in California... damn you liberals in California... caused just one more thing to go wrong on my car here in OH...
Hope that helps
Ron
