Trubonetics T3/T4 hybrid - Subaru WRX Forum
post #1 of 27 Old 10-20-2005, 12:40 AM Thread Starter
bluedub is an unknown
how would the Turbonetics T3/T4 hybrid turbo work on our cars? i have WRX and im looking for some pretty good power from it. if i did get it, how would i compensate for the additional fuel i would need? i thought i would just get a an afc, ### i dont want to get the AP, Ecutek, or anything else like that. is there anyway i could go with an afc, some injectors, and a boost controller?
bluedub is offline
post #2 of 27 Old 10-20-2005, 04:19 AM
stileguy's Avatar
stileguy is an unknown
yes you could do things that way as in japan they usually have all manor of gadgets on their cars which work perfectly ok even on the most highly modified machines. however when these cars get imported into australia as low volume imports this stuff gets thrown out and replaced with a standalone ecu or reflash and usually makes more power and costs half the money to get tuned and drives smoother, but everything comes down to your tuner.
stileguy is offline
post #3 of 27 Old 10-20-2005, 08:38 AM
Cosmo's Avatar
Images: 15
The AFC doesn't have enough range of adjustment to control larger injectors. The AFC takes the stock ECU signal and modifies it. That's fine on stock injectors, but with larger injectors, it doesn't have enough range.
Also, you will need some way to control boost and timing. You can't throw on a bigger turbo and not change all the aspects of your engine management. By the time you buy an AFC and a good boost controller, you'll be over the price of a reflash and close to the price of a UTEC. A UTEC or a reflash does everything you need easier and more reliably.
And, the extra money you are going to spend having custom piping made for that turbo would be better spent on engine management and a more sensible turbo like a VF34.
Cosmo is offline
post #4 of 27 Old 10-20-2005, 03:50 PM Thread Starter
how much power do you think i could get out of a VF34? and its pretty expensive, so are there any other turbos out there that are a little bit cheaper but still put out good power like that?
bluedub is offline
post #5 of 27 Old 10-20-2005, 04:54 PM
the vf34 is not a cheap turbo. It's known for a quick spool. If you just want more power, you could go with a vf22. It's usually cheaper and offers 20-30whp more than a vf34. The difference is that it spools slower so the power comes at higher RPMs, later in the power band.
but you'll learn to just do what cosmo says He knows best
post #6 of 27 Old 10-21-2005, 08:23 AM
Cosmo's Avatar
Images: 15
You could get a VF30, which is the same as a VF34 with just slightly slower spool. They are usually a good bit cheaper than the VF34. But, in reality, $800 for a turbo with an internal wastegate isn't a bad price.
Cosmo is offline
post #7 of 27 Old 10-21-2005, 11:28 AM Thread Starter
Which one would recomend Cosmo? the VF22 or VF30?
bluedub is offline
post #8 of 27 Old 10-21-2005, 12:22 PM
nick4592's Avatar
With those two as your choices look into the EJ5-40T....a much better turbo than both of the IHI's and in the same price range.
nick4592 is offline
post #9 of 27 Old 10-21-2005, 01:37 PM
Cosmo's Avatar
Images: 15
I would suggest the VF30 of the two. The VF22 can produce a slightly higher amount of peak power, but with more lag. The VF30/34 is the best turbo I've seen for a street car and for someone not looking to make huge power numbers.
Cosmo is offline
post #10 of 27 Old 10-21-2005, 04:49 PM
nick4592's Avatar
You should check out the 40T...a great street turbo with quicker spool than a VF34/30 and higher peak power than the VF22.
nick4592 is offline
post #11 of 27 Old 10-22-2005, 12:15 AM
smores's Avatar
smores is an unknown
Send a message via AIM to smores
nick4592 loves his EJ5-40T's Every time I think of a turbo, I will think of that
smores is offline
post #12 of 27 Old 10-22-2005, 01:33 AM
stileguy's Avatar
the ej5-40t looks like a tdo5h turbine side with an 070 housing with a TDO5H core with a custom comp cover and i guess a TO4E 40 trim comp wheel, anyone know what this apparently effective combo really is or the inducer and exducer dimensions of both comp side and turbine side, it looks like it maybe a size or 2 up from a super 16g comp side with identical turbine side. Probably a good competitor to a TD05h-18g with a tdo6 comp cover. what is the highest wheel hp reading that has been achieved at what boost pressure?
stileguy is offline
post #13 of 27 Old 10-22-2005, 10:23 AM
nick4592's Avatar
F YEAH
The highest WHP I have seen is 347 with 351ft lbs. As far as the dimensions to my understanding the inlet is bigger than the 'super 16' and I am not exactly sure about the rest of the details...I am just a product user...but Brian will
nick4592 is offline
post #14 of 27 Old 10-23-2005, 10:22 PM
Momemtum is an unknown
It's not really the size of the wheels that is special about these turbos, it's the machining of the hot side. That's the secret.....
Momemtum is offline
post #15 of 27 Old 10-23-2005, 11:13 PM
wrx904 is an unknown
The deadbolt super 16G is a little bigger than the EJ5-40T, and deadbolt gives you a free lifetime rebuild. I was looking at a VF 34, EJ5-40T, and a super 16G for a while. I am glad I got a super 16G, because why go cheap with something some important. The EJ5-40T has not been round for that long compared to a VF34 or deadbolt super 16G. Also, you can upgrade a deadbolt super 16g to a 18g or 20g if you want more power down the road.
wrx904 is offline
