top mount intercooler - Subaru WRX Forum
post #1 of 12 Old 06-20-2006, 05:59 AM Thread Starter
bluedub is an unknown
would a bigger top mount intercooler sufficient for 16g running stock boost? i have a utec set up and everything, i was just wondering if it would be big enough.
bluedub is offline
post #2 of 12 Old 06-20-2006, 06:53 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Yes that would work
Ian is offline
post #3 of 12 Old 06-20-2006, 07:17 PM
trek98xc's Avatar
trek98xc is an unknown
Send a message via AIM to trek98xc
Yup. You can even up the boost a bit if you want.
rob
▼SbiΣ Mi▼
trek98xc is offline
post #4 of 12 Old 06-21-2006, 08:01 AM
TMICs can be supportive of BIG power.. Depending on how big you go.. I have a PERRIN TMIC and a Garrett GT35R running 21psi and I put down 425awhp with it.. So depending on which one you go with you should be fine..
post #5 of 12 Old 06-24-2006, 03:01 AM
wrxsti01 is an unknown
what is the big difference between TMIC and FMIC?
wrxsti01 is offline
post #6 of 12 Old 06-24-2006, 06:23 AM
9d2TSi's Avatar
The core size and amount of piping are the big ones. Well, besides the obvious design differences.
9d2TSi is offline
post #7 of 12 Old 06-24-2006, 09:44 AM
Like Stacy mentioned about the piping and core size,can make a difference in spooltime/throttle responce.A TMIC maybe has about 1-1.5 ft of piping from the turbo outlet to the I.C. where a FMIC can have almost 6ft.When you are not in boost and go into boost the I.C. system (core and piping) will have to be pressurized first before the cylinders will start to get pressurized.This is one way 100% atmospheric BOV's really decrease performance on the fact that the stock divertor/recirculating valve plumbs that pressure back into the system and keeping the I.C. system pressurized to minimize lag.On the stock TMIC its pretty easy to get that re-pressurized but on a FMIC system,depending on the turbo,you will have to rebuild that pressure up again.Alot of this also is picking a system that is designed properly for your needs.The core size and the pipe size make the difference.I.C. piping is sized just like exhaust pipes.You match it to the CFM going in and size it to keep maximum velocity with the least amount of resistance.To small and it will choke the turbo,to big and it will cause unnecessary lag.The core type,size and configuration make a difference as well. http://www.are.com.au/techtalk/intecoolersMR.htm
dumdum is offline
post #8 of 12 Old 07-03-2006, 03:16 PM
BigJay's Avatar
BigJay is an unknown
you can also get an aluminum Hood Scope Diverter.....it sends half the air to the front of the intercooler making it cool more efficently. You can get one off of E-bay for like $25. I'm not trying to advertise for him but it a great product for the money. I put one on mine 04 and noticed it's cooler when I get done with a nice long hard run.
BigJay is offline
post #9 of 12 Old 07-03-2006, 04:33 PM
bigbadbuddha's Avatar
Images: 15
DumDum you should change your name. I've read that article before and it was an eye opener. Good job dude.
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #10 of 12 Old 07-03-2006, 05:33 PM
stang hunter is an unknown
I have a 16g from turbochargers.com a turboxs front mount 650cc injectors and a 255 fuel pump sitting here. Im planning on puting it on this weekend and getting it tuned next monday. I will let you know what i think about the lag issue and post my numbers.
stang hunter is offline
post #11 of 12 Old 07-03-2006, 11:00 PM
oldfartracer's Avatar
oldfartracer is more helpful than not
FP 16G with a HyperFlow TMIC running 19 psi with out problems. If you are a drag racer the FMIC is better than a TMIC, it has been tested and proven.
oldfartracer is offline
post #12 of 12 Old 07-09-2006, 06:29 PM
Fodera04's Avatar
Fodera04 is an unknown
about the air splitter, i have been looking around and all the ones that i have found are said to fit the 02-03 wrx. would they fit and bolt up to a 04 wrx scoop?
Fodera04 is offline
