im going to be keeping the stock turbo, how much boost will i be loosing if i got FMIC, the only mods im doing is full TBE and cobb stage 2 and then after that im trying to make the car look nice and clean for exterior mods, i wanted the FMIC b/c it looks sick but how bad is it on a stock turbo with those two mods?
It's not realy "LAG" so much as Pressure drop. In all honestly it's the same thing.. You really should keep the stock TMIC. When stepping up to a FMIC the volume of space that is added needs to be pressurized just like it does with the tmic.. Adding the larger FMIC core and extreme length of piping requires much more time for the same size turbo to pressureize..
my humble opinion would be to get a bigger tmic ,something like the STI , aps or hyperflow tmic .it gives much better cooling and doesnt have that tremedous pressure fluctuates of the fmic kit.
if not , go for the v mount set up as the pipings are reasonably shorter than that of aftermarket fmic kits and doesnt set you back as much lag.
Waste of money i already asked this question a couple of weeks ago and they said if your not getting a bigger turbo keep stock or if i want to waste my money get a bigger top mount
