timing belt kit? - Subaru WRX Forum
post #1 of 17 Old 11-09-2009, 02:13 AM Thread Starter
Boober909's Avatar
Boober909 is an unknown
timing belt kit?
so when i start my car/ turn the wheels all the way my timing belt squeals and it's getting annoying. i think it's time to replace it. since i was already going to take this all apart i was thinking about putting a lightweight pulley in as well. i have 120,000 kms on my car (70,000mi) should i do a full timing belt kit/ water pump while i'm in there? also what kind of timing belt should i buy either way? just stock or greddy or something??
thanks.
Boober909 is offline
post #2 of 17 Old 11-09-2009, 09:45 AM
umm thats not your timing belt squealing...its your power steering belt...if it was your timing you would be having a lot bigger of a problem than just a squeal...
post #3 of 17 Old 11-09-2009, 10:39 AM
Yeah... timing belts are usually good until about 100,000 miles.
post #4 of 17 Old 11-09-2009, 12:58 PM Thread Starter
Boober909's Avatar
Oh okay is it a big job to replace the power steering belt?
post #5 of 17 Old 11-09-2009, 02:52 PM
c2bcoolwrx's Avatar
You should also check your timing belt tensioner, as those tend to go more quickly then the belt.
c2bcoolwrx is offline
post #6 of 17 Old 11-10-2009, 08:38 PM
It should take you under 10 minutes to do it. You might just bee able to tighten the belt to get the squeal to go away, if the belt is in good condition.
nagyhead is offline
post #7 of 17 Old 11-11-2009, 10:36 AM
Subaru recommends replacing your drive belts (not timing belt) every 60,000 miles or so, so it sounds like yours may be in need of changing. Spraying a can of belt dressing on squealing belts is NOT a good idea. My brother's 98 Dodge Dakota pickup had squealing belts and the belt dressing didn't fix the problem - it just made a huge mess under the hood from the belts spraying the stuff everywhere. Also, +1 to the belt tensioner being a common failing part.
post #8 of 17 Old 11-11-2009, 07:23 PM Thread Starter
Boober909's Avatar
yeah well when i had my engine rebuilt last winter the guy told me the fan belt was the wrong one and theway it was now the adjuster was tightened all the way, so i needed to replace it with the proper one so i could adjust it. but being kinda lazy i hadn't done anything about it but now that it's almost winter i thought i probably should. is the fan belt the same one that runs the power steering?
post #9 of 17 Old 11-11-2009, 07:23 PM Thread Starter
Boober909's Avatar
don't ask me why he didn't replace it when he had the whole engine out of the car...
post #10 of 17 Old 11-11-2009, 08:43 PM
VD5505's Avatar
Fan belt??? they are electric fans!
VD5505 is offline
post #11 of 17 Old 11-11-2009, 10:27 PM Thread Starter
Boober909's Avatar
k well i guess maybe he said the power steering belt i dunno haha it was like 8 months ago.
post #12 of 17 Old 11-11-2009, 10:44 PM
VD5505's Avatar
what i would do is just get both new belts and put them on, that way you are covered and have two new belts and they are not much money at all.
VD5505 is offline
post #13 of 17 Old 11-12-2009, 12:48 AM
^ Agreed. That's your best/safest option. Plus, then you won't have to do it again for another 60,000 miles
post #14 of 17 Old 11-12-2009, 05:50 PM Thread Starter
Boober909's Avatar
yeah so should i replace the timing belt tensioner as well? and anyone have any oppinions on lightweight pulleys or are they pretty much all the same? i saw the perrin one for around 90 seems decent.
post #15 of 17 Old 11-12-2009, 06:58 PM
VD5505's Avatar
did the guy put a new tensioner on when he rebuilt your engine? pulleys are kinda a waste of money it really depends what your going to do with they car, but everyone has there own opinion on that. just stay with the stock diameter of the crank pulley, you can get a lighter one but just make sure its not under driven
VD5505 is offline
