01-23-2013, 08:30 AM
#8 (permalink)
Aside from being an actual bov and the potential issues with it, it's also a BIG valve.
I run the QR which is the same 50mm design as the Q, just recirculating. The issue with it is at low boost levels there isn't quite enough air to open the valve fully so you get a bit of compressor stall. As long as it does it at low boost/load and not when you hammer it then you're fine. The one thing you need to make sure to do is run a dedicated line off the intake manifold to the top port (aka no T's off for a boost gauge or anything), and make sure it's a good size line so you get as much air to the valve as possible.
The q does have a pretty nice sound, but honestly the QR has a much different sound than my oem valve did and I did feel like it provided a bit better throttle response because it STAYS SHUT until you let off.
