tgv valve number 1 removal - Page 2 - Subaru WRX Forum
post #16 of 44 Old 06-08-2009, 03:04 PM
and UP is up pipe.... sorry about that. I don't know about the weldless project.... Haven't looked into it.
post #17 of 44 Old 06-08-2009, 03:34 PM Thread Starter
cooperwrx's Avatar
cooperwrx is an unknown
Oh all right, yeah I already have a Perrin up pipe in which was a pain. And thatís how I believe I broke the tgv sensor number one. I think I might just get the weld less kit and have our fam friend port it for me. Unless someone had a bad experience with the weldless
cooperwrx is offline
post #18 of 44 Old 06-10-2009, 05:31 PM
GrimmSpeed is an unknown
Send a message via AIM to GrimmSpeed
Shoot us an email if you have any questions,
sales@grimmspeed.com
We'd love to answer any questions you may have.
GrimmSpeed
GrimmSpeed is offline
post #19 of 44 Old 06-11-2009, 12:12 PM Thread Starter
cooperwrx's Avatar
oh wow thanks alot! ill be sure to do that
post #20 of 44 Old 06-11-2009, 03:15 PM Thread Starter
cooperwrx's Avatar
Hopefully one of my last questions about this..! But since I have that tgv closed code and I get the deletes and spacer will my car still run poorly with out a tune? I got my boost gauge up and going and when the car is running bad, it’s only boosting 6 pounds..! Now is this closed code a mechanical problem (the flap is closed) or is it an electrical problem (ecu making a fuel cut and or boost cut ect). Because I would hope it’s a mechanical problem so I can at least drive the 3 hours to the tuner..
PS the 8mm spacer is sold out, Is the 3mm even worth buying??
post #21 of 44 Old 06-12-2009, 05:40 AM
Look into KSTechnologies for their spacers (I picked a set up a while back ).... I would think it's an ecu issue since the tgv is jacked...
Ask Mike or Justin at Grimmspeed how long till they can get you one ?
Just stay out of boost for the drive....
post #22 of 44 Old 06-12-2009, 11:49 PM
Hopefully one of my last questions about this..! But since I have that tgv closed code and I get the deletes and spacer will my car still run poorly with out a tune? I got my boost gauge up and going and when the car is running bad, itís only boosting 6 pounds..! Now is this closed code a mechanical problem (the flap is closed) or is it an electrical problem (ecu making a fuel cut and or boost cut ect). Because I would hope itís a mechanical problem so I can at least drive the 3 hours to the tuner..
If there is a malfunction with the TGV it is not an ECU issue. Either there is an issue with the sensor or the motor that drives them. I have even seen where the flap got warped and wedged closed.
You can only use the 8mm IM spacer if you have a FMIC. The TMIC has clearance issues if you run the 8mm spacer.
Kjott21 is offline
post #23 of 44 Old 06-15-2009, 05:53 AM
^ No. Just like anything... you have to play w/it. Mine has ZERO fitment issues.
post #24 of 44 Old 06-15-2009, 09:48 AM Thread Starter
cooperwrx's Avatar
hey guys well i ordered the weld less kit on friday and i hope it all works ha. i was thinking about getting a perrin turbo inlet tube while i got the IM off but im not to sure yet well see
post #25 of 44 Old 06-15-2009, 10:11 AM
Do yourself a favor... Get an APS hard inlet since the IM and TGV's will be out. MAKE sure you get it for your year and make.
post #26 of 44 Old 06-15-2009, 03:31 PM Thread Starter
cooperwrx's Avatar
hmm i found them for 240. anyone find them any cheaper?? (APS inlet)
post #27 of 44 Old 06-16-2009, 05:32 AM
Did you look on NASIOC (I hate that place for anything more than classifieds) Some of the vendors will beat that (PM them).... saw it not TOO long ago for 219.00 shipped.
looked around a bit... that looks like a decent price.
post #28 of 44 Old 06-16-2009, 08:36 AM Thread Starter
cooperwrx's Avatar
got them!
alright alittle tight on cash for the inlet but how does this sound for my build.
right now i got:
APS 3inch catless DP
TGV deletes
Perrin uppipe
Perrin BOV
Perrin intake
Perrin Boooost controller
H&R springs
(my car will run with the deletes in right??)
On its way:
HKS catback TI 3inch exhaust
OEM spark plus from subaru
Going to perssion tuning.
is this a pretty good build for now? and would you guys suggest something else (not alot of money) im planning on doing more but not for a while.. anyone have a rough idea what my hp/torque might ball park be around?
post #29 of 44 Old 06-16-2009, 12:09 PM
Get an aftermarket boost solenoid.... maybe not a 3port unless you will be going to a bigger hairdryer in the future. Everything else looks good for now.
post #30 of 44 Old 06-16-2009, 04:21 PM
04wrxhart is an unknown
I have a question about PnPing the TGV's. Do the holes where the motor on each TGV connect to the rods in the middle have to be plugged ? If so what should I use to plug them. I got my hands on a die grinder and have been going to town on my friends intake and head for on his honda and im really satisfied with my work. And I cant wait to pull my TGV's off and clear and PnP them.
04wrxhart is offline
