TGV problem (bank open) in WRX 2005 - Subaru WRX Forum
 2Likes
  • 2 Post By boo-key
post #1 of 3 Old 06-09-2014, 05:41 PM Thread Starter
Paddydee's Avatar
hello
hi i get Subaru Impreza WRX 2.0T 2005 (UK version), this is good car, i like buy subaru since long time ago and now i have it since week i have problem with TGV. this the fault code
P2011 TGV - INTAKE MANIFOLD RUNNER CONTROL CIRCUIT/Open bank2a
so i buy new sensor and new control electric engine, i change over, delete fault from ECU but after engine run the fault back again, i try do this 5-6 times but i cant remove fault from ECU, the bank is open now so any way that should be fine but i need repair it and delete fault. i dont know where i can find reason of this problem
thanks for any help
Paddydee is offline
post #2 of 3 Old 06-09-2014, 06:28 PM
boo-key's Avatar
If your sure the replacement parts are good your next step should be checking the harness. Check the wiring harness from the tgv to ecm for cuts, broken wires, wires pulled out of connector pins, or any other damage. You can also test resistance and continuity from one end to the other. Also check connectors for broke, loose, corroded, or missing pins and anything that would cause a bad connection. If all this checks out, start checking grounds.
Brockton and Epictofer like this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #3 of 3 Old 06-10-2014, 05:10 PM Thread Starter
Paddydee's Avatar
thanks for replay, i will check connection btwin ecu and tgv in weekend, i find in service manual step by step how check cables so we see... i like ask u in UK version he ECU is located at left (pasanger) side or like in EU version at right ?
thanks
Paddydee is offline
