TD04 PnP - Subaru WRX Forum
post #1 of 19 Old 07-20-2012, 05:58 PM Thread Starter
AllExtinct's Avatar
TD04 PnP
Thinking about doing some port and polishing on the engine and gonna start on the turbo since its looks like it needs a good cleaning and the easiest to get to.
When I first got the car and changed the inlet hoses I saw a lot of oil blow-by so I know it needs a good cleaning.
Any tips on disassembling without having to worry about causing a headache.
Or any thing to look for while its out.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #2 of 19 Old 07-20-2012, 06:22 PM
It's a BIG PITA once you remove the clamp on the turbo, I know that much.
Your daily driver?
post #3 of 19 Old 07-20-2012, 09:04 PM
Well depends on how far you really wanna go to make it worth while? If I were you I'd consider buy another turbo to upgrade or send it to Blouch for their 19T upgrade.
post #4 of 19 Old 07-20-2012, 09:19 PM
Im with Keith about picking up a used one (I have one btw ). And if you have blow by an AOS or catch can does help alot (even tho it doesnt solve all your problems).
post #5 of 19 Old 07-21-2012, 12:16 AM Thread Starter
AllExtinct's Avatar
Yeah I got a catch can some time back never got around to putting it on.
I was kinda thinking about picking up a used one just, was already checking out a used intake/exhaust manifold's
And whenever I got a beater for work Im gonna try to do the Throttle body,Headers
Cross over pipe & Up pipe.
Using it for DD right now so I dont have that much down time to work with.
Also found this link to take the turbo apart not sure if TD04 would be the same exact process but should be close right? Turbo Rebuild
JDM ej205 swap.
Home state: PA Crew
Chuck.
post #6 of 19 Old 07-21-2012, 07:51 AM
If your going to rebuild a turbo do it right. Send the center section out and have it balanced. Other than that it's pretty straight forward assembly. Although i don't have an 11sec stock turboed car so i know nothing on the subject.....that just doesn't get old.
post #7 of 19 Old 07-21-2012, 03:51 PM
^No it doesn't LOL.... Get a used one and do it right. How many miles on on the one that is on the car now?
post #8 of 19 Old 07-21-2012, 11:01 PM
Just get a VF73 or whatever makes these cars run 11's and your golden....
post #9 of 19 Old 07-22-2012, 09:38 AM
VF73... LOL
My wife's Foz has 88K on the td04 and I think it's headed to be a paperweight soon. Although my k04 on my speed has 115K, it's still holding strong. Ehh, Borg Warner vs Mitsu I suppose.
post #10 of 19 Old 07-22-2012, 08:15 PM
VF73... LOL
Usually that's the other way around...Mitsu turbos last better than Borg ones do...Just ask any Audi owner....
post #11 of 19 Old 07-23-2012, 06:29 AM
I've been seeing that of late and I don't understand what these guys are doing to these hairdryers. Only thing I can think of is irregular OCI's. Who knows
post #12 of 19 Old 07-23-2012, 11:37 AM
Piss poor maintenance is what it is.
post #13 of 19 Old 07-23-2012, 01:20 PM
Not I... Maybe the reason mine has lasted this long.
Oh, sorry to derail your thread Chuck.... As you were.
post #14 of 19 Old 07-23-2012, 03:22 PM
Yeah back to buying a PNP VF73 turbo...
I would suggest just upgrading to something else or getting a stock one rebuild. Honestly it's just not worth the hassle on a stock turbo. Unless you are searching for a record of some sort...hint hint...
post #15 of 19 Old 07-23-2012, 06:01 PM Thread Starter
AllExtinct's Avatar
Thanks for the input guys.
If I upgrade the turbo gonna need a Pro-tune right?
I was just looking into just cleaning the TD04 up to get a lil more life out of it since it has 122k on it.
I checked the shaft when I swapped my DP and didn't notice any so guess that's a +.
JDM ej205 swap.
Home state: PA Crew
Chuck.
