Old 12-20-2004, 09:28 AM   #1 (permalink)
Car: 04 WRX
Reputation: wrx555 is an unknown
tbe and uppipe install
Hey guys...
I just want a little feedback...
I was thinking of installing my tbe and uppipe by myself here in my garage...
To save on install cost...
I've read on some forums that some people could actually do it by themselves in just one night... It was like a straight forward install..
Now my question goes, is the install really that straighforward and people with some know how can handle it??
Or is paying for the install a really better alternative??
Thanks guys!
Old 12-20-2004, 09:38 AM   #2 (permalink)
Cosmo's Avatar
It depends. I have installed several uppipes. If you have a lift, it's very easy. If not, figure about 4 hours minimum. You need 12 and 14 mm sockets (preferably with a long extension) and an O2 sensor socket. You will also need copious amounts of WD40 or Liquid Wench.
Old 12-21-2004, 08:00 PM   #3 (permalink)
Noogin's Avatar
Reputation: Noogin is an unknown
Send a message via AIM to Noogin
Originally Posted by wrx555
Hey guys...
Thanks guys!
I have put a couple of up pipes on and the only thing i can tell you is take your time and use new gaskets. the last thing you want is to put it all together and find a exhaust leak.
If your not confident with your work, I suggest taking it to a shop that has put many up pipes on.GOOD LUCK!!!
Old 01-10-2005, 12:48 AM   #4 (permalink)
Car: 04 WRX
Reputation: mvig1011 is an unknown
I just installed a perrin uppipe. It took me about 6 hours and I have minimal experience and no lift. My car is still somewhat apart as I am waiting to get a downpipe to install while my car is up on blocks.
The uppipe came with a resistor to put in the egt sensor plug. I was wondering if anyone has any suggestions on how to keep it in place? Also, I removed a "lower turbo heat shield" which bolted to the stock uppipe. Is it okay to not reinstall this since there is nothing to bolt it to?
Finally, what is the best catted downpipe? I want to run a single high flow cat in the least restrictive location. (I don't actually want the cat, but I do want to pass emissions)
Thanks
Mark
Old 01-10-2005, 08:36 AM   #5 (permalink)
Cosmo's Avatar
A lot of people use a dab of silicone to keep the resistor in place.
As for the catted downpipe, I don't have any experience with them, so I can't help.
Old 01-10-2005, 12:04 PM   #6 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
I like TXS's. That is what I have.
