TBE: Cobb vs APS vs Lachute(custom) - Subaru WRX Forum
post #1 of 24 Old 11-28-2008, 05:56 PM Thread Starter
WRXDre is an unknown
Hi everyone, I will be upgrading my 05 wrx to "stage 2" next spring, and for the last few months I've been browsing the net for a good TBE. Like the titles says I've narrowed my choices down to 3 models, APS, Cobb, and a local shop that makes custom exhausts(very good rep) all of em being 3" and catted.
I've only heard good things about all 3 models, but they all have 3 different design at the turbo end. here are some pics
APS: Name:  split_hfto.jpg
Cobb: Name:  BellMouthDetail.jpg
Lachute: (couldn't find a picture of the "bellmouth" so i made one with paint using hks model)
From what the people at Lachute told me their "semi bell mouth" design is just as good as a full bell mouth, since it still allows gases from the waste gate to flow down the down pipe. I would probably go for their model since their shop is 1 hour from where i live but this "bell mouth" thing is confusing me.
I'd like to hear someone else opinion. And if you ever had experience with any of those products (good or bad) please post them here.
Thanks
Dre
WRXDre is offline
post #2 of 24 Old 11-28-2008, 08:32 PM
isd_intrepid's Avatar
isd_intrepid is an unknown
Send a message via Yahoo to isd_intrepid
IMO:
go with the cobb. or you can get the same design by invidia from rallysportdirect.com for cheaper.
In essence the bellmouth design allows for more free flowing exhaust. Somebody like MOSC or DumDum or Turmic can explain how it works. As for the diff on the cobb vs the APS. the only diff there is the APS has a divorced wastegate. which divides the flow of the exhaust. which i guess in some world would make a difference if it went to a different pipe. in this case it just goes your exhaust system. the last one. trust me. dont get it. if you take off your current DP and compare the 2 your going to be in for some heartache.
isd_intrepid is offline
post #3 of 24 Old 11-28-2008, 11:38 PM
I run the Cobb TBE, love the look, sound and quality of it. APS says in their directions that you have to grind the divider some to make it fit depending on turbo application. You want some type of bellmouth as it is the best flowing since there is no real "true" divorced setup out there. That lachute, if anything like your depiction, is next to being stock it looks like. The stock DP is a terrible design. I need to get a pic posted here so newer people know how bad it is, just too lazy, sorry about that.
post #4 of 24 Old 11-28-2008, 11:47 PM
I've never heard of a "semi bellmouth" downpipe before. If you're going to replace your stock downpipe, your best bet is to get a full bellmouth design. None of this inbetween nonsense. There are inexpensive bellmouth downpipes out there, just search around. But if you don't mind paying for it, I'd highly recommend Cobb's downpipe. I'm a little biased though since that's what I have. A+ quality. A+ fitment. Plus, it will mate to any cat back you choose, even the stock one.
post #5 of 24 Old 11-29-2008, 12:04 AM
tuner ready's Avatar
Images: 11
tuner ready is an unknown
I love my COBB downpipe. The quality and fitment are one of the best. I just went with a reputable company since the downpipes are one of the important pieces in our exhaust system.
tuner ready is offline
post #6 of 24 Old 11-29-2008, 12:37 AM
Get a full bellmouth design. The 3/4 bellmouth sounds like a really stupid idea.
If you are buying on a budget get a Megan Racing DP.
Kjott21 is offline
post #7 of 24 Old 11-29-2008, 01:07 AM Thread Starter
Thanks for you inputs guys. Here's a picture of the actual Lachute DP:
About Lachute, that's where I'm going to get my car tuned. From what I've heard they're the best in my area, the shop has been around for 8-9 years. I thought their "semi-bell mouth" design might work as good as a "full bell mouth". The owner of the shop showed me where the turbo end of the down pipe would meet with the turbo on a VF-39. It covers about half the waste gate, so the gas doesn't hit a wall like the stock unit, instead it goes down the down pipe. He also told me that the waste gate doesn't have to open all the way, meaning the difference between their design and a bell mouth isn't much different in terms of power gains since they both allow gases from the waste gate to flow in the down pipe.
I've just found out that the APS and Cobb use cast iron at the turbo end of the down pipe. Is that something i should consider in my choice?
One more thing, will a divorced bell mouth help reduce turbulence in the exhaust flow between turbine/waste gate? Or would that just be the case with a divorced down pipe.
Thanks again for sharing your knowledge.
Dre
WRXDre is offline
post #8 of 24 Old 11-29-2008, 01:20 AM
Originally Posted by WRXDre View Post
TI thought their "semi-bell mouth" design might work as good as a "full bell mouth". The owner of the shop showed me where the turbo end of the down pipe would meet with the turbo on a VF-39. It covers about half the waste gate
Since you brought up the question about the turbulence in the exhaust flow what do you think that covering half of the wastegate will do in terms of the turbulence? That is just a terrible idea.
The divorced WG is a better design in theory but you will run into problems with some of them hitting the WG on an aftermarket turbo. The best divorced DP I have seen is the one that Element Tuning came out with followed by BPM. Both of them have the WG reentering the exhaust flow way down stream to keep the turbulence at a minimum.
Kjott21 is offline
post #9 of 24 Old 11-29-2008, 01:11 PM
WRX_Fan_0717's Avatar
WRX_Fan_0717 is an unknown
Is it me or does the Lachute looks like for EWG applications?
Semi or divorced DP are just not as proven as a full Bellmouth. Well divorced in theory (turbulence) are suppose to be better but i'll take my bellmouth.
I would get the full 4" TXS DP personally. Cheap and effective. Plus, switch out the car anytime you want in 10 minutes (track etc). Get the stealthback and like a full 3" non fart can axleback.
Meth'd, EWG'd, Str8 Cut PPG'd, 20G'd Bug-i, 354awhp and 315tq SAE 5 Corrected 50/50 meth @ 19-20psi.
WRX_Fan_0717 is offline
post #10 of 24 Old 11-29-2008, 02:13 PM
if you think the shop is going to give you what you need. go with them. and when your done. I'll be happy to match off with you.
post #11 of 24 Old 11-30-2008, 10:41 AM Thread Starter
MadDad
That's what I'm planning on getting. I don't want the extra attention from a loud exhaust, I'm just looking for a deep rumble without going overboard.
I also found a fully divorced waste gate down pipe from MadDad that looks really neat. Heard a lot of good comments over at the NASIOC forums. From what I've heard, it might just be what I'm looking for in terms of sound. (and no droning sound at any rpm!) I'd just like to see if any of you guys have had experience with that system or know people that have it. Or just general thoughts on the down pipe.
Here are some pics:
Down pipe:
The cat looking thing at the end of the DP is actually a guard to prevent damage to the 02 sensor.
Cat-back:
There's a flex joint at the end of the mid-pipe, never seen that before. Good? Bad?
Cat-back Twin-tip:
WRXDre is offline
post #12 of 24 Old 11-30-2008, 10:52 PM
Maddad is an excellent choice.
That flex pipe means they company actually thought about long term durability and less chance of cracking a tubular header ......i would say GOOD.
Top notch crap.
post #13 of 24 Old 11-30-2008, 10:59 PM
Here's mine:
Notice anything outrageously big......no you don't. Clean is what i notice.
It's a WBR (black can model) full 3" looks kinda like the OE STi can but a tad bigger. Running it with the TXS EWG UpPipe/TurboBack.
Suppose to be as quiet as say the maddad but it's a little loud from me being catless.
post #14 of 24 Old 11-30-2008, 11:00 PM
You can here it at the beginning of this video:
When it gets really loud it's the EWG opening not the exhaust.
My Blouch 20g'd EWG'd PPG'd Meth Injected 02 WRX o- Video
post #15 of 24 Old 12-01-2008, 12:35 AM
Here's mine:
Yup, squeaky clean.
I like the shaved keyhole and is that an STi limited spoiler? You, sir, have excellent taste.
