Stock TMIC + Blouch Dom 3(.5) - Page 2 - Subaru WRX Forum
post #16 of 18 Old 08-15-2011, 07:15 AM
I honestly believe that the ports are just not doing you any favors. Although I have head that if you hog out the ports really well, you can see big gains with the right set of cams.
post #17 of 18 Old 08-15-2011, 08:39 AM
Originally Posted by daletron View Post
really?
I would think that the shyte cooling efficiency (especially on a dyno) and flow rate of the stock unit would have a rather large impact on top end figure?
The power your putting out is basically what a stock 2.0L with a VF39,pink injectors,TBE and stock TMIC puts out. I agree with psinuse about the heads. A somewhat easy fix is to slap in a set of used STI cams. They are cheap and plentiful but you do have to block off the AVCS holes. Tap and set screws work.
dumdum is offline
post #18 of 18 Old 08-22-2011, 06:38 PM
I would agree with dumdum and psinuse. I'm going to be running a Dom 3.0XTR soon. Will be getting a FMIC after my pistons get broke in. But...I will have: head work, cams, built bottem end, and many many other small upgrades. I would say the Dom 3.0 series is not a turbo for TMIC use.
