cool, this is exactly the kind of replies I was looking for! guy at work has a stock 02, going to plug into the data link and see how it reacts to airflow changes, and changes in fuel demandas far as getting power out of other cars by leaning them out, thats not always true. the Mitsubishi computers actually increase the injector pulse length in response to increased airflow. tested it out with a CAI on an Eclipse GSX, had 3/4 of the open element filter blocked off (had approx. the same volume readings as when it had the stock intake system and air filter) pulled off the restrictor, and within 30 seconds the short trim levels adjusted for the increase in airflow. 2 minutes after that the long trim adjusted itself to bring the short trim back down to zero, allowing an immidiate adjustment to be made again should the need arise. the EGT's stayed solid, no knock detected at all. I think the Scooby puter doesnt have that kind of adaptability.
will let you know my findings of the tests!
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
