Wondering what a stock catback sounds like with an dp / up.
Trying to mod my wagon up, but cash is a little lacking lately, I dont want to shell out the money for a decent catback until I've done other mods (Unless it is ultimately important to get one before going on).
Planning on purchasing an Invidia up, Invidia high flow cat dp and a cobb accessport. Then Deatschwerks 565 cc injecters, walbro fuel pump, ebay tmic, and a VF-39.
How rough is the tuning via maps from cobbs?, After doing these upgrades I plan on getting it pro-tuned but I don't know any shops near me so I'll probably be ridin with the cobb maps for a while.
Well the problem you are gonna run into is that there aren't any cobb ap maps that are just with a DP and stock exhaust...its either stage 1, which is a stock car reflashed or stage 2 which is FULL turbo back exhaust. I've heard of people using a STi cat back with a aftermarket DP, dont know how its gonna sound though. If you are gonna spend any money I'de go with the AP first, then TBE. You didnt specify what year your car is so we dont know if its a 2.o liter or a 2.5 liter wrx. the 2.5's have boost spiking/creap problems...
Do you have a drop in filter or intake? I def recomend going with the ap first...especially if you dont have any tuners in your area. They have quite a few maps for the wrx's.
So I can count on the maps being a good enough tune to where I dont need to get some final tweaks done by a tuner? Unless of course I decide to add any mods that arent supported by cobb maps.
and on the note of local tuners, I see your nearby, you wouldn't happen to know of any good shops ?
Hit up Intro Flat4NC - www.flat4nc.com There are a couple tuners closer to Raleigh than they are to me
Draco performance is one and I forgot the name on the other one the guys name is robbie. The ap maps are pretty generic and run pig rich from what I've heard. I've also heard that a protune is :rocks: But expensive, expect to pay at least 350 bucks for one.
you dont need a catback. The map only calls for a downpipe. I have the cobb catless downpipe with the stock catback and it sounds alright. I wish it was louder but it i like it.
You dont need a catback, just the DP for stage 2. The stock catback isnt too restrective unless you are looking for big power. Im running basically just a Cobb (catted DP) right now, lol, the CBE I had doesnt match but its still there till my Cobb CBE comes in. It sounds alrite, but like was said, even more power can be made from a tune over the (known) rich Cobb maps.
Cobb AP is the way to go. I have an Sti catback, K&N drop in, and im running stage 1. From what i hear cobb DP is made to go with the stock Cat Back. Thats what i want to get. Just with stage 1 you will feel a nice difference.
if you are intersted i have a HKS Catback that i had on the car for a year. I can sell it fairly cheap. I also have a no name bellmouth DP. All you would have to do is get the Cobb AP.
Look into a SR-S catback.... 200.00 and sounds like any other N1 out there. Not too loud. Do a search on you tube and eBay. Good seller on eBay is nissangtpower
i just did an up and dp on my car this weekend, sounds alright minus the exhaust leak, putting a 3 inch dp to the stock cat-back doesn't fit perfectly.
Even though these injectors have the same flow rate as STi Pink injectors, they probably should not be used with the cobb base map. Every injector performs a little differently and it'd be safer if you went with the exact injectors the map was written for IE pinks...
Was looking into these ones that are specifically made for use with the Cobb AP, Saw maps for these injectors and for the sti ones.
The Deatschwerks injectors seem like a better deal !Thumbs Up'
I'm thinking about getting Cobb's CBE or Stromung's dual tip, I don't like the look of exhausts with tips 4 in or bigger....
I see now that they've added maps for both pinks and those Deatschwerks injectors so yeah, you should be good either way. Just use the correct one. I guess they just came out with those maps recently, that wasn't always the case. Yay cobb!
I do take a little smirk of glee from this though that I knew enough to know that it was an issue and that cobb is backing me up by putting out two different maps accordingly
