Stock cat back with Helix DP - Subaru WRX Forum
post #1 of 15 Old 07-06-2006, 10:08 PM Thread Starter
Speedogomer's Avatar
Speedogomer is an unknown
Send a message via AIM to Speedogomer
Alright, I know this has probably been posted somewhere, but after searching and searching, I'm starting a new thread, sorry guys.
I've been told different things about the Helix Catted DP mating to the stock cat back. I just ordered the Helix DP and called Scoobytuner to see if I needed an adapter to make it work with the factory cat back, they told me it would fit without problems. The Helxi states its a full 3" so I was under the impression I needed to get a flange to make it fit. If I do need it, any suggestions on sites where I can get one?
Also I've heard the UP and DP install can be a pain. I have a lift, all the tools other than an O2 socket (plenty of other sockets), and a few friends to help. I was wondering if it would be worth it to have it installed by an exhaust shop or should I just get a case of beer and install it myself.
p.s. I'll get the case of beer even if a shop installs the UP and DP, so don't let the beer influence your advice.
p.s.s. It will be Miller Lite
-Justin, aka Gomer
(sold)-05 WRX
(new)-04 Cadillac CTS-V
Speedogomer is offline
post #2 of 15 Old 07-06-2006, 10:26 PM
oldfartracer's Avatar
oldfartracer is more helpful than not
I run the 3" HKS DP with a stock 2.75" STI exhaust. No bolt up problems.
oldfartracer is offline
post #3 of 15 Old 07-06-2006, 10:34 PM
dewrx02 is an unknown
if it was coors light i'd come help you you and your buddies could knock it out in a day im havin my shop put my new ones in since its getting ra gears in the trans anyway.but you should be fine good luck
dewrx02 is offline
post #4 of 15 Old 07-10-2006, 11:41 AM Thread Starter
Anyone else running a 3" DP with the stock CBE?
-Justin, aka Gomer
(sold)-05 WRX
post #5 of 15 Old 07-10-2006, 01:10 PM
Jave's Avatar
Jave is more helpful than not
I tried it but it did want to line up right. But it might have just been me.
▼SbiΣ Mi▼
Jave is offline
post #6 of 15 Old 07-10-2006, 02:58 PM
theaxemaster is an unknown
If they're flanged the same then they'll bolt up, its just going to create backpressure. I'd personally wait for the catback though.
theaxemaster is offline
post #7 of 15 Old 07-10-2006, 04:07 PM
It has been dyno tested that you will only lose 5hp with the stock CBE. If you are on the stock turbo, a 3" exhaust is not needed. You will lose some low end.
post #8 of 15 Old 07-10-2006, 10:48 PM
gingertooth is an unknown
i was running that but didn't sound any different and it felt like crap compared to an 3 inch catback.
gingertooth is offline
post #9 of 15 Old 07-11-2006, 10:11 PM
jeneah's Avatar
jeneah is an unknown
I'm interested to see how that would bolt up myself. I have a 2.5 cat back but I plan on getting the helix dp too. I'd be glad to help if you want.....pm me I'm only a couple hours away..
Jeff
jeneah is offline
post #10 of 15 Old 07-12-2006, 02:03 PM
no, you won't. This isn't some NA VTEC honda. You get plenty of backpressure from the turbo itself. A cutout gives no noticeable drop in low end, let alone a 3" exhaust. As for the catback costing you 5hp, not on a stock turbo it won't. The stock catback is not a restriction until you get into larger turbos
post #11 of 15 Old 07-12-2006, 02:08 PM
six3jag's Avatar
six3jag is an unknown
Send a message via AIM to six3jag
+1 for catted DPs. Hope thats what you are saying your putting on. I like my helix catted DP alot.
Jacob
Almost clean wrx...
six3jag is offline
post #12 of 15 Old 07-12-2006, 04:52 PM
WRX_JUNKI's Avatar
WRX_JUNKI is an unknown
Send a message via AIM to WRX_JUNKI
I am currently using a 3" Invidia V2 downpipe mated to a stock catback and the fitment is fine. I put a gasket in between and no leaks so far.
Even though you guys say it does not matter much when going with 3" exhaust to something smaller, I'd beg to differ. I went from HKS Hi-Power(full 3") then to Fujitsubo Powergetter (3" with tapers at the connections) and now the stock catback. There was a noticeable difference as I kept going smaller. I even felt a difference between full 3" and the tapers. I plan on getting a full 3" when I am getting a new catback.
Oh and the stock catback with aftermarket downpipe does not sound good and wastegate flutter is all you hear at light throttle.
Keith
WRX_JUNKI is offline
post #13 of 15 Old 07-12-2006, 04:58 PM Thread Starter
It's a catted Helix DP, I need the cat to pass PA inspection, and I want to keep things relatively quiet. Here all they do is a visual inspection for a cat on the car, some people just bolt a peice over a catless exhaust to just make it look like it has a cat on it. Or if you know the shop well enough, they'll just let it slide and slap an inspection sticker on it.
-Justin, aka Gomer
(sold)-05 WRX
post #14 of 15 Old 07-12-2006, 11:11 PM
mxboy15u's Avatar
mxboy15u is an unknown
Over on Nasioc a guy posted the highest stock turbo numbers ever with a stock catback on. I forgot what they are but they were insane. I run a stock catback, and plan on doing so with my vf30 as well.
mxboy15u is offline
post #15 of 15 Old 07-13-2006, 02:33 AM
FuBuRaCeRs is an unknown
is it true that invidia and perrin are merging to compete with helix? i know some dude that works at a scooby dealer here in texas and he knows his shit.
FuBuRaCeRs is offline
