I asked COBB about the stock turbo's efficiency with Stage 2 power:
"With Stage 2's 16.5 psi boost (plus 14.7 atmosphere) is a 2.12 pressure ratio, and air flow rate is estimated to be at 017 m^3/sec from the How to Read Compressor Map link below.
How to Read Compressor Map:
How to Read Compressor Maps... - CICENetwork - Forums
Is the OEM TD04-13T turbo approaching it's efficiency range in a standard Stage 2 application, or operating beyond it?
I know less efficiency means more heat, and I suspect COBB would've designed Stage 2 to be within a practical operating range of the OEM turbo.
Any insight you have would be helpful.
Thanks,
Laszlo Toth, P.Eng. | Associate Manager, Fuel Pricing & Rewards | Fuels Marketing |
And they say that with their maps boost tapers off in the upper rpm range intentially, because of efficiency.
"John (COBB Support)
Sep 12 04:02 PM
Hello Laszlo,
This is the main reason we design our maps to taper down towards redline to prevent the turbo from becoming a heat pump. You will still be good on our OTS maps.
Here is a good link. Compressor Maps | Turbobygarrett
Please let us know if you have any other questions.
Thank you,
ph: 866-922-3059
web | blog | facebook | twitter | youtube"
Thanks,
Sep 12 04:02 PM
Hello Laszlo,
Thank you,
ph: 866-922-3059
