stage 2, well almost - Subaru WRX Forum
post #1 of 33 Old 02-16-2009, 03:41 PM Thread Starter
04wrxhart is an unknown
so i got my uppipe in for safety and im getting ready to order a downpipe. first off i know im not a legit stage 2 untill i get a tune or a em tool. and i wanted to ask if its safe to run the DP without a tune. from what i know, i think it would cause no harm to my engine as far as boost etc. and im not just saying this to get outa paying for a tune, i am going to get one down the road i just dont have the cash atm. and yes i know i wont get the full power gains without the tune. i am going to get a catless dp. will i run into any issue's here with the o2 sensor or will it still funcion fine ? im thinking about getting the R*SR DP. i know some of you out there have one and i want to hear from you guys, how was fitment and how satisfied are you with it. my second option is the cobb DP. i know cobb is a good brand its just a little pricey. i know the quality of the cobb dp will be greater then the R*SR dp but is that the only advantage ? (yes the R*SR is a bellmouth.) as far as gaskets i know to get the oem ones. what about buying a used DP off a wrecked suby or something ? do you guys think it would be safe to use ? any other suggestions on DP's would be nice. lemme know what you guys are running with.
If you cant tell im driving a 04 wrx and i believe the turbo in the 04's are boost creep free ? so by running catless or highflow catted DP i wouldnt have to worry about boost creep, please correct me if im wrong.
04wrxhart is offline
post #2 of 33 Old 02-16-2009, 04:30 PM
This answer is only valid for 02-05 WRX EJ205 powered cars:
You don't need EM with a downpipe. However, it is strongly recommended.
post #3 of 33 Old 02-16-2009, 04:52 PM
tuner ready's Avatar
Images: 11
tuner ready is an unknown
The difference between COBB and SR*S is quality and fitment. Won't you get a CEL if you are running catless without a tune? You could always store the downpipe somewhere and then install it once you get a tune.
tuner ready is offline
post #4 of 33 Old 02-16-2009, 05:03 PM
you may get a CEL if you run a catless downpipe without a tune. You can fix this without tuning though. All that is required is a resistor. 2.2kohm
post #5 of 33 Old 02-16-2009, 05:11 PM Thread Starter
ya i did the 1/2 watt 2.2kohm resistor trick for the egt sensor. u can do the same thing for the DP's o2 sensor i assume then ? is that healthy for your engine though ? and tune wise, what would you guys lean too. an actual pro tune or and Engine management tool ? i think i would have more fun and feel like im getting more out of a EM tool like the cobb ap but its $700.00 and i think thats just rediculous... does cobb have a finance plan ? lol
post #6 of 33 Old 02-16-2009, 06:09 PM
phatmike0704's Avatar
phatmike0704 is an unknown
Send a message via AIM to phatmike0704 Send a message via Yahoo to phatmike0704
i ran my catless up pipe and catless down pipe for half a year without a tune and i raced a lot. But i definelty do not recommend it. i was running so rich im surprised my engine didnt blow. CEL did pop up after a week, it was my emission control unit. my friend tunes my stock ecu but the code is still bein thrown. GET THE TUNE, u already need it with the up pipe anyway
phatmike0704 is offline
post #7 of 33 Old 02-16-2009, 09:08 PM
Don't do the DP till you have EM.
Kjott21 is offline
post #8 of 33 Old 02-17-2009, 03:57 AM Thread Starter
what would you guys reccomend though, a pro tune or something like a cobb ap or something along those lines ?
post #9 of 33 Old 02-17-2009, 04:06 AM
Unless you are getting tuned with open source, you will have to buy an AP,UTEC,EcuTek License or standalone unit before you can get a protune. There is at least one open source tuner in the Arlington, WA area. His name is Dom Acia and here is his website: MPS™ ::# Custom Tuning Services## “Get a Dom Tune!”®
Kjott21 is offline
post #10 of 33 Old 02-17-2009, 04:31 AM
RenoSTi is an unknown
I'd recommend getting the Cobb AP and then a protune.
RenoSTi is offline
post #11 of 33 Old 02-17-2009, 11:38 AM Thread Starter
i have another question... if i were to buy an married cobb ap off of someone would cobb reset it to defaults if i sent it into them, has anyone tried this ?
post #12 of 33 Old 02-17-2009, 12:40 PM
That would be stealing and no they wouldn't be stupid enough to fall for that.
You should look into open source tuning. It's free.
post #13 of 33 Old 02-17-2009, 02:59 PM
ya i did the 1/2 watt 2.2kohm resistor trick for the egt sensor. u can do the same thing for the DP's o2 sensor i assume then ?l
No, it doesn't work like that. You need an o2 simulator. They usually consist of various resistors and/or capacitors. If you're handy with electronics, you can probably build one yourself.
I will be another say that you don't necessary need a tune, but it's HIGHLY recommended. I ran stage2 without a tune for about 2.5 years on my 04.
post #14 of 33 Old 02-17-2009, 05:24 PM
They will do that. You would have to pay a stupid amount of money for them to reset it. They make it almost as expensive as buying a new one.
Kjott21 is offline
post #15 of 33 Old 02-18-2009, 01:15 AM
Images: 11
You will love stage 2 though. Flashing to stock tomorrow :*(. Going to miss the stage 2 power!
